Post new topic  Reply to topic  [ 103 posts ]  Go to page Previous 14 5 6 7 811 Next
 Post subject: Re: Stereo Tool 7.00
PostPosted: Sat Dec 15, 2012 11:34 am
I don`t see "This sound is processed by..." that often . It`s normal in 12 hours like it seems . I` don`t know
Btw, Who said "this sound is...... " Hans is this you ?
Because the voice is really good recorded and looks like the operator of the radio station is doin this :)
PostPosted: Sat Dec 15, 2012 1:15 pm
Lol! It's a horrible recording... Made using the right built-in microphone of a cassette recorder I got when I was 8 (the one on the left sounds less good :shock: )... But yeah it's me. :oops:
PostPosted: Sat Dec 15, 2012 2:05 pm
DONE:
- VST version should work properly now
Sorry, but it still doesn't work. In fact it's a bit worst, because this time I can't even set anything, it just doesn't react anymore at all. The GUI does stay visible now though, even after closing and then reopening.
PostPosted: Sat Dec 15, 2012 2:15 pm
Yes working in Reaper.Cheers Hans!
PostPosted: Sat Dec 15, 2012 2:52 pm
Is there a chance of changing the font on the RDS Text in the "Output Signal " window?
When DSP window is minimized it really can't be read, and when open in full view, it is still hard to read.
File comment: Max window
File comment: Minimized window
PostPosted: Sat Dec 15, 2012 4:22 pm
VST issues: I'll try yet another approach, something in between what I used before and use now. If it works in Reaper I'll post it here (unable to test this Ploque thing because you cannot download it anymore unless you buy it).
PostPosted: Sat Dec 15, 2012 4:55 pm
I purchased a Stereo Tool 6.32 & DeClipper license in September 2012. What is the upgrade price for v7? Sorry if I missed this somewhere else.
PostPosted: Sat Dec 15, 2012 5:02 pm
There's no upgrade price, all license (even those bought for version 3) still work. So just install the new version :)
PostPosted: Sat Dec 15, 2012 5:05 pm
New VST version, confirmed to work with VST_Scanner, dBpoweramp, Reaper, VST Host DSP. Screen update method is much closer to what I used in version 6.32, so I hope this will fix the issues. (Will add the stand alone and DSP version later).
http://www.stereotool.com/download/vst_ ... 01-002.dll
http://www.stereotool.com/download/dsp_ ... 01-002.exe
PostPosted: Sat Dec 15, 2012 7:17 pm
Both Beta7.01 VST versions work in Adobe Audition 6, Win7 64
VST 7.00 didn't open.
