Especially the Loudness filter *has* to introduce lower freqs sometimes because it leads to a better audio quality. At least make sure that you turn the option there off... (Bottom of the Loudness panel, something with allowing DC offset).
It actually says:
Forcibly remove DC component caused by loudness (reduces quality!)
Based on your thinking it said the reverse (to allow it), I would guess I'd want to try enabling it.
Edit: Yeah, so that didn't do what I wanted. Didn't really appear to do much of anything.
I think a fundamental misunderstanding exists. I think you don't understand what I want.
There is absolutely no need for me to have a lot of content in the 0-35 (or 0-40) range. Your high-pass, once everything else is factored in, seems to give about -20 to -30 dB of cut, gradually, getting to that level of cut at 20 Hz when set at 35. What I'm looking for is something "wild and crazy", such as -40 to -60 dB of cut, with a sharp drop (high corner, if I'm reading and understanding correctly). Even that isn't as steep as the low-pass, which seems to be -60 to -90. The 25 Hz area has as much energy with the current high-pass design as some of the midrange. That means that in the total mix, the inaudible, and unplayable (unless you have really professional grade equipment) content is robbing power that could be used elsewhere in the mix. To combat the effect, I have to raise the mids and highs louder than what they normally would be to survive through the mix, which leads to pushing a higher RMS level for the entire mix. It's either that, or sacrificing the 40-80 Hz region, which destroys modern dance music / RnB / hiphop.
Now, I can try to find an additional plugin, but handling it that way means the mix produced by your product will need tinkering and will not sound the same unless someone also uses the additional plugin.
Finally, a great frustration to me is that you are asking questions about my settings inside your product, when you could visit the preset forum, download the preset, and use it for yourself. I think if you actually took a look, it might get us on the same page, or at least in the same chapter.
