Post new topic  Reply to topic  [ 55 posts ]  Go to page Previous 1 2 3 4 5 6
 Post subject: Re: De-clipping filter
PostPosted: Mon Mar 28, 2011 11:14 pm
By the way, the Stereo Tool declipper won't cause any extra latency :P - it runs in the latency that is already there for the rest of the processing.
PostPosted: Mon Mar 28, 2011 11:26 pm
Any beta soon ? :)
PostPosted: Tue Mar 29, 2011 11:10 am
See v6.10 thread in News forum :-)
PostPosted: Wed Mar 30, 2011 11:24 am
New idea: EXPANDER filter PER SAMPLE. Exact opposite of clipping. Will also cause similar artifacts as clipping. But that means I can also filter them out as I do for Loudness... Might be worth a test! (And can be done in a few hours).
And the good news is: This will affect compressed audio MUCH more than 'natural' audio.
(This is NOT a declipping filter, but a dynamics boost filter, which I expect to boost the dynamics of compressed audio way more than of not compressed audio).
This is probably not as good as the idea I had before, but it's so much simpler that I really want to try it out first.
Interesting to check: 1. Run extreme phase rotation 2. make actual histogram match phase rotated histogram (maybe boost difference to twice as much).
PostPosted: Wed Mar 30, 2011 10:15 pm
Works! And sounds quite good too! (And I haven't even made it content-dependent yet!)
Edit: Hm. Only works on bass sounds. Still, the effect on the total audio is really good. Will post new beta later tonight.
