Post new topic  Reply to topic  [ 71 posts ]  Go to page Previous 14 5 6 7 8 Next
PostPosted: Fri Oct 20, 2023 7:18 pm
I've ordered a 5 for testing, and we'll update the image once the 5 is here so I can verify that things actually work. We will most likely also add a "Pi 5" target to the CPU settings.
The update might be a bit more work than just an apt update, because we have made lots of changes to the image, and we'll have to make sure that the update doesn't undo those changes and that the low latency behavior (for PiMP among others) is still ok.
PostPosted: Fri Oct 20, 2023 7:51 pm
I am testing as we speak on a RPI 4. A lot of changes....... Probably on the same image use different configs for RPI 3/4 and RPI 5.
https://ibb.co/bNDMfcB
https://www.raspberrypi.com/software/op ... -os-64-bit
To update with Hifiberry and Raspberry PI 5 support:
https://www.hifiberry.com/blog/pi5-comp ... -products/
PostPosted: Mon Jan 29, 2024 9:33 am
Were can i find the update file for version 4.2.3?
In the BETA topic there is only a beta version.
PostPosted: Mon Jan 29, 2024 10:30 am
Dou you mean this? https://www.thimeo.com/micrompx/download/#Pi
Ross
PostPosted: Mon Jan 29, 2024 11:58 am
No the update file. On this page i can't find it.
I think this is it: https://download.thimeo.com/ThimeoPi64U ... llProducts
PostPosted: Mon Jan 29, 2024 3:27 pm
I think this is the one you want https://www.thimeo.com/how-to-use-the-r ... ard-image/
For some reason, I can only find this link when browsing the PiMP or STudio page on the Thimeo site
PostPosted: Thu Feb 01, 2024 1:05 am
You are right.
PostPosted: Thu Feb 22, 2024 6:00 pm
The Pi 5 image didn't work before, it should work now: https://www.stereotool.com/download/Thimeo_Pi345.zip
PostPosted: Wed Mar 13, 2024 9:57 pm
I installed this on Rasp Pi 5 - 8 Gig and it works for about 10 minutes and then goes into a reboot loop after I put in the license key.
Any ideas?
Greg
PostPosted: Wed Mar 13, 2024 10:07 pm
There are issues with the Pi 5 HifiBerry drivers. But, are you getting audio for those 10 minutes? If so, which exact sound card do you have?
