Post new topic  Reply to topic  [ 78 posts ]  Go to page Previous 14 5 6 7 8 Next
PostPosted: Tue Feb 12, 2019 10:51 am
The last few betas create an empty dsp_stereo_tool.log folder at the same place where the ini-file resides. Is this intentional?
PostPosted: Tue Feb 12, 2019 11:02 am
No!
PostPosted: Tue Feb 12, 2019 1:05 pm
I see you have added RDS group sequence.
I have try this new fonction, but i see no difference, i have try this sequence for exemple:
0A,0A,0A,2A
I have see at analyzer and at the monitoring tab, that not effects on RDS signal. it's normal ?
And i have a another question, i have a station with a single frequency, for a optimisation, i need to transmit the 0B group (With NO AF) instead the 0A group, it's possible on futur versions ?
Thanks you for your very good job ;)
PostPosted: Tue Feb 12, 2019 1:25 pm
Hi Damien,
I've just tried your sequence and it works here, both in a separate analyzer and in the monitor tab I only see 0A and 1/3rd of that number 2A groups, and a 4A once per minute.
PostPosted: Tue Feb 12, 2019 1:37 pm
I have rewrite the sequence, disabled and re-activate rds and now it's ok... it's probabely a mistake from me Hans, excuse me.
For the 0B Group, you have a response ? ;)
PostPosted: Tue Feb 12, 2019 2:45 pm
The Bojcha’s preset Stargate Ultra FM has set the lowpass frequency to 0 Hz and then is not audio (only silent) in the "Normal Output". See here viewtopic.php?f=10&t=25663&start=10#p58302
https://fmfeeling.com
PostPosted: Tue Feb 12, 2019 4:10 pm
Yes, fixed for the next build.
Not now, but I could see that it's useful to add this sometime.
PostPosted: Tue Feb 12, 2019 4:17 pm
Thank you for your response Hans
PostPosted: Tue Feb 12, 2019 7:49 pm
Just to explain a little: A very big client is going to use our RDS encoder for a lot of transmitters very soon, which is also why I added all these new RDS features. I don't want to risk breaking anything now. (That risk is already big enough with all these new features, but they need them).
