Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 289 posts ]  Go to page Previous 14 5 6 7 829 Next
PostPosted: Sun Jun 24, 2018 6:39 pm
I just installed stereo tool 9 and it will not accept my license number.using the vst 64bit with natural dynamics and Declipper.
edit: Ignore this message I got it running!!
PostPosted: Mon Jun 25, 2018 6:14 am
9.01 is up on the main release page. In the thread 9.01 says Beta 001.
Just a little confused by that. Is 9.01 the official release now or still a Beta?
PostPosted: Mon Jun 25, 2018 6:36 am
I only see 9.01 mentioned in the release notes. I downloaded it again and it still shows as 9.00 on the title bar. The file sizes are the same as well..
PostPosted: Mon Jun 25, 2018 9:35 am
9.01 is coming today. It will fix nearly every issue that was reported on 9.00 in the last few days.
I finished it on Saturday evening - unfortunately running a full build, even on my 4.2 GHz GHz i7 with 32 GB of memory and SSD drive, takes about 30 hours now (I have some ideas to speed it up, will look into that soon - I hope to be able to get it below 10 hours again so I can run a build in one night again).
PostPosted: Mon Jun 25, 2018 1:41 pm
That is damn too much. Can gpu compile that?
PostPosted: Mon Jun 25, 2018 2:33 pm
GPU's are made for parallel floating point math and SIMD operations which doesn't play well with compilers.
PostPosted: Mon Jun 25, 2018 7:39 pm
Error in input device via VLC, audio is restarted and lock screen
Edit:
error only VLC 3.0.3
VLC 2.2.4 works perfectly
PostPosted: Mon Jun 25, 2018 8:19 pm
Edit:
Yup, it doesn't work with VLC 3 yet. They apparently changed their interface, I have to look into that. For now, please use VLC 2 (I explicitly changed the name VLC to VLC everywhere to indicate this).
PostPosted: Tue Jun 26, 2018 5:48 am
I just downloaded the version from the homepage (for Winamp) and it's reporting 9.00 as the version number, not 9.01
Is this just a cosmetic issue, or the build for Winamp wasn't updated?
PostPosted: Tue Jun 26, 2018 7:44 pm
Im using the 64 bit vst version STEREO TOOL 9.01 (JUNE 26TH 2018) inside Reaper.Resizing the window causes white blank screen flashes
