Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 758 posts ]  Go to page Previous 14 5 6 7 876 Next
PostPosted: Fri Dec 15, 2017 11:15 pm
heheheh! thanks ..but i need an FM preset and not a streaming low dbr preset.
Can we now talk about the latest beta of stereotool?
enough !! If you can make a 11 or 12 dbr preset for fm broadcast just ..tell me :)
PostPosted: Fri Dec 15, 2017 11:28 pm
That's easy to do: just turn up some sliders and voila.
About the latest beta? Why can't I fill in a hostname instead of a IP in the stream encoder?
PostPosted: Sat Dec 16, 2017 10:28 am
I don't think such things should be available to unskilled and unqualified persons.
PostPosted: Sat Dec 16, 2017 6:03 pm
Well, there's a point to be made there. On the other hand, if you've worked with Optimods, you understand the frustration of not being able to "fine tune" the machines, because the manufacturer felt such flexibility was too dangerous to be placed in the hands of "unskilled and unqualified persons". Instead of a plethora of detailed sliders to work with, we got "Less-More".
Better, I think, that the product has been released as Hans has done it. Those who take the time to understand, and study, and work with this thing in a professional manner can get a really great sound out of it that no other processor on the market can come close to.
In the areas I've placed the software, the station is easily as loud, with a sound you can stay with for hours. Compared to most others here, these stations immediately stand out, more for being open and loud (enough) than loud, clipped and strident. Hans really has done a great job.
For most, the drive to be loudest disappeared in the mid-70s... and certainly after we all went to digital radios. Maybe that's something else to consider... The star of this thread may be operating in a country where all the radios still have analog tuners. :mrgreen:
PostPosted: Sat Dec 16, 2017 6:31 pm
I think that i ve found a " usual suspect " of loss on dynamics on this " high loudness " preset i ve made.
Keys : stereo enhancing was out of strict control. = fixed
limiters on multiband2 where ...out of control = fixed
Thanks for your feedback!
I ve made something better and still extremely loud ( on FM broadcast )
11,5 dbr at most songs and with dynamics and no audible compressors !
Your triggering made me better ! Thanks!
:roll:
http://stream.grap.gr/1045fm ( de-emfasised to be listenable as ...a stream :)
check it to see if it is better , but do not trust only 1 or 2 songs !
PostPosted: Sat Dec 16, 2017 6:42 pm
Hi Hans, I got the following message when listening to some songs, could you please explain to me what it does mean? Thanks!
PostPosted: Sat Dec 16, 2017 7:00 pm
Basically what the text says. If the AGC, on average (over a long period of time) does almost nothing, this message will pop up. The reason is that I've heard several stations that were feeding their audio at something like -24 dB, just selected some built-in preset, and that was it. Since none of the presets will boost the input by 24 dB, the AGC will do nothing at all (and the multibands won't do much either). And the result is a very soft and very non-consistent sound.
Do you think that in your case the message is invalid? Then I might have made it too sensitive...
PostPosted: Sun Dec 17, 2017 7:53 pm
:roll:
Its sounds like a bluetooth speaker in a toillet whith dj toillet duck..what a crap! ;)
Garbage in is Garbage out !
PostPosted: Sun Dec 17, 2017 11:17 pm
GUI Exception... See pic
PostPosted: Mon Dec 18, 2017 12:30 am
Were you doing something (adjusting settings?) or did it just happen with no apparent reason? (The numbers point to the first MB compressor, so it must be caused there or before it).
