Post new topic  Reply to topic  [ 155 posts ]  Go to page Previous 14 5 6 7 816 Next
PostPosted: Wed Nov 01, 2017 12:07 am
@Wunjo: I think I found the cause... too aggressive optimization. Not 100% sure, but I hope that the next build will work.
Hans. this part, Low CPU on Auto EQ (AMD) is OK now :-)
It fixed my problem. I had the same exception, but different address and offset info.
PostPosted: Wed Nov 01, 2017 5:41 am
Hi Hans:
I found a Issue.
Version BETA 007 - x64 on Windows 10
Best regards from Chile
PostPosted: Wed Nov 01, 2017 11:54 am
Hi Hans:
I found a Issue.
Can you send me your settings? I found the location of the crash, but it's in a file that I haven't changed in months... Please save your *full* settings (SAVE -> ALL SETTINGS).
PostPosted: Wed Nov 01, 2017 1:27 pm
Oops, my ProppFexx just crashed with the new VST plugin.
32 or 64 bits?
@Gunther, could you save your settings (SAVE - ALL SETTINGS) and send them to me (via PM or email)? I doubt that it's VST related, it's probably related to the settings that you're using, but since I don't have those and don't have an error message I don't know where to look. Both the 32 and 64 bit VST version are working fine on my end.
Edit: I just tested in ProppFrexx on my end and it works fine here (in fact, at first ProppFrexx itself crashed, which was caused by the fact that I recently installed Pro Tools on my pc and ProppFrexx apparently didn't like that, ugh! So I had to uninstall Pro Tools to be able to start it again). Anyway, I need more info, a copy of what's logged in the Windows Event Viewer would really help a lot too.
PostPosted: Wed Nov 01, 2017 2:59 pm
I think that multiband analog mode compressor are broken with RMS detector, because attack shape and time strong depends on release shape, it's make no sense for me. In average compatybility and peak this behavios looks quite normal.
Urban Junglist
PostPosted: Wed Nov 01, 2017 3:50 pm
Do you have a shape value where it's very different? I had to rewrite that whole calculation for the optimized mode so it could very well be wrong. But for the settings that I tested (and I tested quite a few) it was very close. Can you send me the compressor settings where that mode on/off makes a big difference?
PostPosted: Wed Nov 01, 2017 4:34 pm
I'll try to explein it
This test was simple, i discovered it accidentally, switched off all blocks expect MB, I have 1kHz looped sine burst tone and when I move slider realese shape - attack is changing like using attack shape, in peak and average is normal - dependency is negligible.
Urban Junglist
PostPosted: Wed Nov 01, 2017 10:45 pm
32bit, PF is V3.0
STS is included
my computer just freezed :(
5bandVSTbeta03.sts [108.05 KiB]
Downloaded 351 times
PostPosted: Wed Nov 01, 2017 11:02 pm
Is the graphical display for the 'Delossifier' gone also? (8.54beta007, Win 32bit standalone)
PostPosted: Wed Nov 01, 2017 11:03 pm
I still see it, Windows 10 64-bit standalone
