Post new topic  Reply to topic  [ 286 posts ]  Go to page Previous 14 5 6 7 829 Next
PostPosted: Mon May 17, 2010 11:22 pm
I just uploaded a new BETA version where the AGC is improved further. "Remove remaining peaks" now causes almost no artifacts anymore.
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 2_BETA.dll
Command line version: http://www.stereotool.com/download/ster ... d_BETA.exe
Things todo:
- Instead of lowering based on max(old method, new method) use max(min(old method, factor * lowest result of new method), new method) - this should better reduce short spikes at the corner of a processing block (loud start of a new track after silence) * NO, does not work better
- (Test if this helps) Dynamically lower the 'Remove remaining peaks' level when the AGC output level is going up for a while. * DONE, waiting for feedback
- Improve performance a bit for the new 'Remove remaining peaks' algorithm (it's heavier than before now, but it doesn't have to be. And the quality will probably get better too). * DONE
- Multiband wider bands :-) * DONE
PostPosted: Mon May 17, 2010 11:42 pm
Bojcha contacted me about it and I had to test it to believe it. Ofcourse he was right (how can we ever doubt him :mrgreen: )
I haven't tested it with pink noise yet but it might cause some unwanted sound colouring and overal loudness could be affected.
PostPosted: Mon May 17, 2010 11:46 pm
Things todo:
Hi Hans, thanks! Just for your record, the last version that worked here with Station Playlist, is the beta released on 7 May. Nothing to worry about, I'm the only one with this problem as far as I know and it might be my config.
PostPosted: Mon May 17, 2010 11:50 pm
Well, that's the thing: Noise (including pink noise) should hardly be affected. Because if 2 consecutive bands have the same amplification (which is mostly the case if you check the output, and definitely with noise), there's no colouring of any kind occurring. Still, a loud tone just between 2 bands can still come out (at least a bit) louder than it should. So solving it might improve things. AND, also important: I *think* that it might also make the output volume from Multiband more constant, which could indeed make things a bit easier for Loudness.
You can consider it like this:
- A single tone is one extreme
- Noise is just the opposite of that (so also an extreme)
- Music is somewhere in between, usually MUCH close to noise than to a single tone (just check a spectrogram and you'll see what I mean)
A single tone if affected by this, noise is not. Music maybe a bit.
PostPosted: Tue May 18, 2010 12:00 am
Just checked it again here, but I'm not seeing any issues (even in Station Playlist). If I could reproduce it I might be able to find out what's wrong - but so far no luck...
PostPosted: Tue May 18, 2010 1:11 am
:evil: ... :)
PostPosted: Tue May 18, 2010 11:06 am
I just measured with a sweep from 20Hz to 20KHz and noticed that the filters cause a 'jojo' effect on the output. Differences in multiband output are huge. Seems that the combined output of the filters is not flat.
LOL! It turns out that I had already 'fixed' this for all but the most extreme cases (actually I went through trouble to NOT fix the most extreme cases...). I just removed a few lines of code, and now:
- Sweep is constant (except at start and end of the range), no more jojo
- Normal music is NOT changed at all
PostPosted: Tue May 18, 2010 12:44 pm
New BETA uploaded, now with flat multiband response.
PostPosted: Tue May 18, 2010 1:12 pm
Are you shure ? :)
As i said on multiband is more attack now. So level must be lowered from AGC. Limit mode and Compress mode are more different.
PostPosted: Tue May 18, 2010 1:26 pm
Are you shure ? :)
You test it and let me know so we can bother Hans :lol:
