Post new topic  Reply to topic  [ 58 posts ]  Go to page Previous 1 2 3 4 5 6
PostPosted: Thu Jun 08, 2017 2:40 pm
This might help you more Hans, Gaps are when Latency is on 2048 and more on 4096 not on less options and 1 thread.
I cannot optimize it further without breaking how it works. Is your CPU close to 90-100%?
PostPosted: Thu Jun 08, 2017 5:23 pm
this is a GAP moment
http://prntscr.com/fhfzwk
PostPosted: Thu Jun 08, 2017 5:37 pm
CPU load is 94%... that's really way too high.
PostPosted: Thu Jun 08, 2017 7:57 pm
ofcourse with 94%, there will be gaps.
PostPosted: Fri Jun 09, 2017 12:14 am
Windows stand alone: http://www.stereotool.com/download/ster ... 36-012.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 36-012.exe
VST: http://---.stereotool.com/download/vst_stereo_tool_BETA836-012.dll
VST: http://www.stereotool.com/download/vst_ ... 36-012.dll
- Test full build with fixed warnings
- ASI test
- NAN error -> Added recovery mechanism
- Reset PNR
- Exception Jelle -> Apparently gone in latest beta
OLD CHANGES
- Check if 'Prioritize loudness" works as planned, doesn't do too much -> Adjusted slightly, a bit more bass around 50-100 Hz (0.05 dB) has only a very small (0.02 dB) effect on mids.
- Optimize new RMS?
- Maybe suggest auto-update for presets? -> No.
- WatchCat 374 error WAITING FOR FEEDBACK
- WatchCat continuous rename error [MATHIJS] WAITING FOR FEEDBACK
- Removed build warnings - TEST PEQ still ok in web interface -> Ok
- Slightly optimized drawable eq display in web interface.
- Test new RMS +0.9 mode levels, compare with old RMS. -> Was wrong, back to +1.75
- Test Covfefe pressure_follower with low frequency sine waves and fast release to make sure that it's roughly correct.
- Test Covfefe pressure_follower with different release times to make sure that it's correct.
- Fix "Not registered" message
- Fix anti-phase. Tested and seems to work, needs to be implemented to always work.
- RDS word wrap chance for ArcticPalm: Split words if needed. Dave Hartman.
- Added Covfefe follower to greatly improve consistency in the new RMS mode for high Covfefe values
- New RMS mode: Compensate for release speed difference. Is going slower now for bigger drop. New RMS mode: Release is slower for bigger distances, should I fix that? -> See new Covfefe slider (I still need to name it properly)
- SST upload / confirm / download / delete presets
- Long STS file names fixed (more)
- Sound card issue in Generic plugin (2 threads)
- Triple ,0 with GUI doesn't work WAITING FOR FEEDBACK
- New RMS mode: Add channel linking (Explanation will follow)!
- There is a settings bug. If you load any preset, the Leif composite strictness seems to go down to 8. I use 9 in my settings, but I have to reset it to 9 anytime I load a preset, even if that preset already uses 9. -> Long names in the STS file were cut off!
- Clipper "Prioritize loudness" mode. Now also works for non-composite clipper, and much bigger effect.
- LW version removed Diff, Hear, Absolute Highs
- AGC bug: Window did not work properly (caused clicking sounds and jumps) with AGC block sizes smaller than the default block size.
- Clipper: Prioritize Loudness works for composite clipper (see Advanced Clipper -> Sound). Might need further optimization.
- Bug fix (8.34): EQUALIZER could change to Phase Delay graph and vice versa.
- RMS same behavior for DC Waiting for feedback
- Bug fix (8.34): EQUALIZER was still not ok, should be now.
- New RMS mode split in 2 modes: "RMS" which has the same behavior as Peak and Old RMS for DC offsets (the standard behavior), and another new RMS mode with 1.8 dB higher thresholds to be nearly identical to the old RMS mode, to make it easier to convert presets to the new RMS mode.
- About box: Add licenses
- Renamed Covfefe to Big release acceleration
- Add preset
- Renumber to 8.40
- RELEASE
Later:
- uMPX web interface
- Smarter stereo-to-mono conversion (only when needed)
- Test clipping
- Classical music compressor
- NAB
PostPosted: Fri Jun 09, 2017 12:15 am
The requested URL /download/dsp_stereo_tool_installer_BETA836-012.exe was not found on this server.
I'm probably just too quick?
PostPosted: Fri Jun 09, 2017 12:18 am
Oops I forgot to run the upload script. It's running now, files should be there in 2-3 minutes.
PostPosted: Sun Jun 18, 2017 2:37 am
i am on beta 9..
Seems in MB1 limiters are always before compressors, or some other bug that make it to work like that.
Also why compressor ratio has impact on limiters? Probably it has something with previous point.
"Covfefe" - I guess it should have something with release but it also have with attack.
I see some very old stuff still not fixed like
- Bass clipper bug (ABDP), it passes very deep bass at around 'i think' 40-50Hz
- ND still does not have input detection
- Still no 'new' AGC (earlier sent close model created with singleband compressor)
- ITU 1770 model still not copied from MB to AGC (they are not same) much more proper one is in MB.. etc
