Post new topic  Reply to topic  [ 172 posts ]  Go to page Previous 14 5 6 7 818 Next
PostPosted: Sat Apr 24, 2010 12:09 pm
Hi On Standalone New Beta2 in "Configure sound Card" Not displayed Souncard selection in all parts( FM, Normal etc) Simply Blanc
PostPosted: Sat Apr 24, 2010 12:55 pm
Hi Boris,
Can you explain more precisely what you see? I've tried it on 2 different PC's (one Windows XP 32 and one Vista 64) here and I don't see anything strange, so I'll have to look for the cause based on your description.
Are the sound card pull-down menu's empty? All of them? Or is the right part of the window empty? Or something else?
PostPosted: Sat Apr 24, 2010 2:34 pm
Yes, the souncard pull-down menu empty. Later i restart PC, maybe its my problem in memory
PostPosted: Sat Apr 24, 2010 3:02 pm
Very unlikely, it must be something in Stereo Tool. Will check it.
PostPosted: Sat Apr 24, 2010 3:12 pm
Could you answer the following?
- Is the INPUT soundcard pull-down menu also empty?
- Is the ASIO soundcard pull-down menu also empty?
- For the other 3: Are there no options that you can choose (ie. you press it and see only 0 or 1 lines to pick from), or are there multiple options which are each empty (sound card names not filled in)?
Which OS do you have?
PostPosted: Sat Apr 24, 2010 3:22 pm
i don't see errors for now ...
i'll put it to transmitter and repeort in few minutes.
edit: all ok here
PostPosted: Sat Apr 24, 2010 3:30 pm
Could you answer the following?- Is the INPUT soundcard pull-down menu also empty?- Is the ASIO soundcard pull-down menu also empty?- For the other 3: Are there no options that you can choose (ie. you press it and see only 0 or 1 lines to pick from), or are there multiple options which are each empty (sound card names not filled in)?Which OS do you have?
Wind XP32, ASIO Menu Set only Julia ASIO. Input and all output is empty...
PostPosted: Sat Apr 24, 2010 5:01 pm
Boris, can you run this .EXE file? It's not an installer but it should start directly. This will write logging to C:\st_log.txt . Please let it run for a few seconds, then send me the log file. Thanks...
http://www.stereotool.com/download/radio_tool_SA.exe
Please open the sound card configuration window during the test.
PostPosted: Sun Apr 25, 2010 10:30 am
Minor update to the BETA2:
- Screen position is remembered now
- SuperH's preset updated to latest version
PostPosted: Sun Apr 25, 2010 2:53 pm
Well done.
now i can try to build this.. when i find this case... :mrgreen:
