Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 148 49 50 51 5259 Next
PostPosted: Tue May 24, 2016 3:40 am
The number in Stereo Tool doesn't actually show CPU load, but the percentage of time spent during processing. So when that gets very close to 100% you'll get problems. Even if Stereo Tool wouldn't be doing much and would just be waiting to get some CPU time this value can be high.
I will try when I get home from Prague.
PostPosted: Tue May 24, 2016 5:57 pm
Hmmm ok
So I have a problem with transit of audio, I need to find where the bottleneck is in my system.
Gonna discuss this in "hardware forum" because it's kinda off topic from the Beta releases.
PostPosted: Fri May 27, 2016 1:22 pm
@damien: Why would you want that??? You want the modulation peaks to be below 38 kHz instead of 75?
The problem is when i can use a loudness sound > 4-5dbr, il need to reduce the sound card for not make overshoots (>75khz). i have make calibration and i have tested with a VX222 and a ESI Juli@, it's the same way.
But i understand or i lost anything :(
If you want i send my preset
PostPosted: Fri May 27, 2016 9:43 pm
For me , if you have a high dbr preset WITH COMPOSITE CLIPPING ...( 8, 9 , 10 dbr at 75 khz ) you need to play at max 62 khz deviation (stereo at 10% and rds at 9 % on 62 khz ...so it will be normal at 62 khz )
62 khz for me ( or even lower... ) is the best for multipath and low signal areas.
YOU CANNOT IMAGINE HOW MANY EXTRA LISTENERS YOU WILL HAVE WITH THIS .
( it is better to be with a loud preset at 62 khz ....than using ITU masks...that make your sound unatural )
:oops: :oops: :oops: :oops:
PostPosted: Fri May 27, 2016 10:54 pm
There are people who are running at +10 dB with my processing without overshoots. Pilot and RDS at default levels. You must be doing something wrong - either that or your transmitter is broken. Did you load a built-in FM preset?
PostPosted: Sat May 28, 2016 7:47 pm
Note to self: nieuw framework, haal x samples op en stuur ze ergens heen. Common functies voor controlesignaal overlaps. Even helemaal los ontwikkelen.
PostPosted: Sun May 29, 2016 3:35 pm
All of a sudden I received this error and it won't go away!
I tried installing 7.84 and 7.85 betas, error still appears on opening Stereo Tool.
PostPosted: Mon May 30, 2016 10:13 am
Can you send me your .ini file? Since it happens in all these versions I'm expecting it to reproduce here as well.
PostPosted: Mon May 30, 2016 3:49 pm
Hi
My 2 cents.
I've this version running 24/7 in webcast since their release with no errors.
OS is XP, sp2.
PostPosted: Mon May 30, 2016 6:52 pm
Thanks - it reproduces here. Will check it.
