Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 758 posts ]  Go to page Previous 147 48 49 50 5176 Next
PostPosted: Thu Apr 05, 2018 6:36 pm
Hm, I probably do need to revisit the default settings for Auto EQ...
PostPosted: Thu Apr 05, 2018 7:00 pm
JdR2 is talking about the sound change between beta 52 (beta 50 for me because I skipped all the NaN-enabled ones) and beta 59. Nobody else hearing any difference?
PostPosted: Thu Apr 05, 2018 7:12 pm
It sounds like the question is: For the exact same settings, do I hear more 3000-12000Hz energy in build 59 versus build 50? My answer to that question would be absolutely not. I hear no such difference. Nor do I hear any other spectral difference between those builds.
PostPosted: Thu Apr 05, 2018 7:54 pm
Band 1: -0.5dB
Band 2: No change
Band 3: -0.1dB
Band 4: +0.1dB
Band 5: -2dB
Wes, what are the target numbers actually? Care to post a screenshot?
PostPosted: Thu Apr 05, 2018 7:59 pm
Band 1: -0.5dB
Band 2: No change
Band 3: -0.1dB
Band 4: +0.1dB
Band 5: -2dB
Band 1: 1.4dB
Band 2: 0dB
Band 3: -1.6dB
Band 4: -6.5dB
Band 5: -9.9dB
It matters, so here's the speeds:
Adjust time: 1.3seconds
Kickspeed up: 0.66x
Of course, none of this makes any sense if you aren't using my crossovers. You can find ones that are close enough in the current versions of any presets in the software that use Auto EQ (which I think is all of them). My brand new work will be available whenever Hans publishes the next beta.
PostPosted: Thu Apr 05, 2018 8:38 pm
There is one of few things in StereoTool that was always annoying to me.. was. Finally not!
Probably someone noticed it, very low "shaking" bass sinusode, wich also makes bass to sound very strange.
Current fix is to just set standard 4096 samples and exactly 107% of qualty. Bass is super stable down to 25Hz wich is enough.
Maybe soon we will see same at 100% Quality.
PostPosted: Thu Apr 05, 2018 8:40 pm
Is it unsatisfactory again at quality levels above 107%?
PostPosted: Thu Apr 05, 2018 9:10 pm
Yea, strange, it's exactly 107%
PostPosted: Thu Apr 05, 2018 9:12 pm
Really bizarre. I haven't noticed anything special about 107% locally. But I think it depends on a lot of factors what % is actually uses. Perhaps there is a difference between our setups.
PostPosted: Thu Apr 05, 2018 10:41 pm
Hello Hans,
Problem with Stereotool VST with Adobe Audition 3 for every Beta release after .50. I am using the VST version, 32 bit. When I load the VST into Audition, the Thimeo menu for Stereotool disappears. I have Perfect Declipper (stand alone) installed as well, and Perfect Declipper is not affected. Stereotool works fine for versions up to .50, but maybe it's something in the logging process that causes Audition to not recognize the Beta update. Have you heard of this from anyone else? OS is Windows 7. Do you need more details?
Ted Alexander - Telos Alliance
Hi Ted!
What do you mean by the Thimeo menu? Do you mean that the whole thing isn't visible anymore under Effects -> VST? I have an older Audition version here and in that version, the last beta (059) runs fine - I haven't tried the in-between versions. There was a bug a few versions ago that caused VST reads to fail, so if that was the problem it should be fixed now.
Yes, it's the Effects->VST listing. In AA3, after .050, whenever I loaded it into Stereotool, and tried to run the 32 bit VST,
the "StereoTool" menu item in the Effects-> VST menu disappeared. The Thimeo "folder" disappeared and left the Perfect Declipper menu item standing alone. (I have the Perfect Declipper 32 bit VST stand alone installed). I did not try .058 since I suspected something in the NAN logging function didn't work right with AA3. I'll load .059 and let you know what results.
Apr 5, 2018.
Hi Hans. Beta version .059 works normally on Adobe Audition 3, VST 32 bit. I tried it on both a Windows 7 and a Windows 10 computer. I'll let you know if I discover any other problems. Thanks.
