Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 476 posts ]  Go to page Previous 144 45 46 47 48 Next
PostPosted: Tue Jun 02, 2015 11:18 pm
Something still seems to be wrong with this beta and/or with your Preset "Analog Pleasure".
This Preset sounded excellent with beta 051, but now the output is distorted.
I am running the DSP Version with SAM Broadcaster.
PostPosted: Wed Jun 03, 2015 12:13 am
Streaming, FM?
PostPosted: Wed Jun 03, 2015 3:39 am
RELEASE CANDIDATE 7.70:
Windows stand alone: http://www.stereotool.com/download/ster ... er_770.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... er_770.exe
Windows VST 32: http://www.stereotool.com/download/vst_ ... ol_770.dll
Windows command line 32: http://www.stereotool.com/download/ster ... md_770.exe
Windows stand alone: http://www.stereotool.com/download/ster ... 64_770.exe
Windows VST 64: http://www.stereotool.com/download/vst_ ... 64_770.dll
Linux 32 bit:
Linux command line: http://www.stereotool.com/download/stereo_tool_cmd_770
Linux GUI/Jack: http://www.stereotool.com/download/stereo_tool_gui_770
Linux 64 bit:
Linux command line: http://www.stereotool.com/download/ster ... cmd_64_770
Linux GUI/Jack: http://www.stereotool.com/download/ster ... gui_64_770
Mac OS X: (WILL BE ADDED TOMORROW)
Mac stand alone (Jack): http://www.stereotool.com/download/stereo_tool_770.zip
Mac VST 32 bit: http://www.stereotool.com/download/ster ... 70.vst.zip
Mac VST 64 bit: http://www.stereotool.com/download/ster ... 70.vst.zip
Mac command line: http://www.stereotool.com/download/stereo_tool_mac_770
- Wait for Diggy Down FM (TURN DECLIPPER ON!) and Jesse Graffam's final streaming/AM/FM presets; answer from Nikolay Vachev; include Uptown FM preset, Sjoerd Wijdogen
- Wait for feedback on which presets to keep/remove/reorganize
- Adjust Simple preset levels
- dsp_declipper.dll build fails in IPO -> Not in Visual Studio...
- Fix crash when switching presets -> was caused by Stokkemask clipper variable updates during processing.
- Adjust FM BS412 preset levels
- Check Analog Pleasure FM sound vs. streaming and Unveil and BS412
- Check RDS time zone issue - apparently still not ok in Brazilian time zone
- Added second Multiband Compressor
- Added resampler for normal output to fix 2 output on different sound cards problem (for example FM on sound card and streaming via VAC/VB Cable).
- Added auto-restart behavior if buffers get too full or too empty.
- Added upto 10 seconds of audio delay for HD radio.
- Added support for built-in GUI skins
- Added option to show beta version number in title bar
- RDS: Added RT+ support.
- RDS: Fixed time zone 30 minute offset problem - viewtopic.php?f=6&t=5941&p=28209#p28209
- GUI: Improved display for bigger screens.
- GUI: Increased maximum waveform display from 3.2 to 5 seconds.
- GUI: Made line around Phase Delay in bottom display less bright.
- GUI: Bug fix: Composite clipper used but not registered warning wasn't shown.
- GUI: Save settings .ini when saving the settings to any file.
- GUI: Fixed delay of Delossifier in display.
- GUI: Fix 'Load default values' question for MB #bands change.
- GUI: Improved Compressors gate and limiter display (new Analog mode only).
- Singleband Compressors: Don't allow Threshold values below 0.5 dB
- Compressors: Made a new Compressor implementation ('Analog'), based on the behavior of water pressure control systems and hydraulic automatically closing doors. Sounds better and uses far less CPU load.
- Compressors: Made new Limiter (only used in combination with new compressor mode).
- Compressors: Made Limit before Compress switchable in old (Digital) compressors.
- After-AGC Singleband Compressor: Added new Analog compressor mode with new limiter.
- Final Singleband Compressor: Added new Analog compressor mode with new limiter.
- Multiband Compressor: Added new Analog compressor mode with new limiter.
- Multiband Compressor: Band Link did not work in 3-band mode.
- Multiband Compressor: Added Freeze/Gate for all bands combined (Analog mode only).
- Multiband Compressor: Fix frequency band shift (10%, since 7.51 or 7.60).
- Multiband Compressor: Fixed a filtering issue when using Density Drive > 1.00
- Improved CPU performance a bit, on multiple places (clipper, GUI).
- Small performance optimizations.
- Optimized synchronization between sound cards code - factor 5 CPU load reduction.
- Multipath Clipper: Made it stricter (use Smoothing mode)
- Bug fix: Linux 32 bit version is working again in Ubuntu 13/14 (was a compiler optimization bug)
- Bug fix: Saving FM sound card issue in VST: viewtopic.php?f=2&t=6027&p=29066#p29066
- Bug fix: Compressors: When gate is set to -99 dB, release stops working.
- Bug fix: GUI: Threshold and knee were labeled 'Speeds' instead of 'Levels'.
- Fixed 'uninitialized memory read' warnings (reported by Intel Inspector XE).(
- ProppFrexx integration: Added RDS control via VST (canDo, vendorSpecific)
WAITING FOR FEEDBACK 7.70:
- Wait for Matt Aaron's feedback about HD synchronization
TO DO 7.70:
- Release
TO DO 7.71:
- EQ with 'standard' sliders.
- Memory leak in Generic plugin (reported by Franciszek)
TO DO WITH LEIF:
- Stokkemask: try if I can move the data a few samples to make 2nd smoothing step unnecessary.
How to use RT+ in RadioText
Put \+xx before and \- after an item
where xx is an RT+ type number (00-63).
Instead of a number you can also use the codes
WW or UR for an URL (type 29)
AR for Artist (type 04)
TI for Title (type 01)
So for example:
Now playing \+ArMadonna\- - \+TiLike a Virgin\-
You can use at most 2 codes. For now, codes are transmitted for ALL the texts, so this only works properly if you have a static RT text. I might change that later.
PostPosted: Wed Jun 03, 2015 4:50 am
Programs that display the version string of the DSP DLL externally, still report it as 7.60, not 7.70. Seems like a version string somewhere is yet to be updated.
PostPosted: Wed Jun 03, 2015 9:25 am
How "externally"? Winamp shows 7.70 in its interface... Some programs might not update without a rescan?
PostPosted: Wed Jun 03, 2015 10:53 am
Hi All
Firstly many thanks to Hans for all the work that has gone into this yet again
Also for everyones input to show up bugs
Bojcha has helped me loads with set up etc
So running latest 7.70 final 64bit with Diggy Down Streaming Preset by Bojcha with ESI Julia soundcard calibrated this is on test today
Please take a listen http://46.28.49.164:7412/stream this is just 128k Mp3 using Edcast
Thanks again all
Matt :D :D :D :D
PostPosted: Wed Jun 03, 2015 1:22 pm
You can not add Linux 64 bit?
PostPosted: Wed Jun 03, 2015 1:25 pm
O I forgot - will edit the post above to add them now!
PostPosted: Wed Jun 03, 2015 2:05 pm
I'm running it now on my ubuntu 14.10 :-)
Thanks!
PostPosted: Wed Jun 03, 2015 2:10 pm
Hi
http://www.stereotool.com/download/stereo_tool_64_770 & http://www.stereotool.com/download/stereo_tool_770 are not active.
Urban Junglist
