Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 758 posts ]  Go to page Previous 144 45 46 47 4876 Next
PostPosted: Sun Apr 01, 2018 9:30 am
I few posts before I have reported a crash DSP 32Bit Beta56.
Winamp closes itself immediately.
Settings are loaded from GAP_7-Elements_v0.7.sts (older sts) and nothing changed.
My Windows Version is Win10 Build1709
My CPU is older I7-3770K.
All other DSP Versions works fine until Beta56.
I hope I could help you.
PostPosted: Sun Apr 01, 2018 9:41 am
I have found the Download Link for my Settings in this Board:
download/file.php?id=1225
The Gap sts File is orginal, I have nothing changed.
PostPosted: Sun Apr 01, 2018 11:46 am
someone confirms me with the abnormal behavior of agc with Drake - god's plan
PostPosted: Sun Apr 01, 2018 5:10 pm
On what part you think?
Listening on my latest preset.. all seems fine.
PostPosted: Sun Apr 01, 2018 5:29 pm
I meant with "AGC CURRENT", in the breaks, especially at the beginning of the file
PostPosted: Sun Apr 01, 2018 6:18 pm
Ah, i dont use that AGC. It's just uncontrolable agressive mostly on release
PostPosted: Sun Apr 01, 2018 6:23 pm
Stereo Tool 8.55 BETA057
Crash in 056 fixed. I know approximately where the (hopefully) last NAN error comes from, will try to fix that tonight!
NAN LOGGING VERSION - BE CAREFUL WHEN USING FOR PRODUCTION! If a NAN occurs AND a directory C:\temp exists, this version will log a lot of data to a file C:\temp\log - during the logging the processing may have severe hiccups. If you have non NAN error problems, this version will run normally, just a bit slower.
Windows stand alone: http://www.stereotool.com/download/ster ... 55-057.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 55-057.exe
VST: http://www.stereotool.com/download/vst_ ... 55-057.dll
- TURNED NAN LOGGING ON - IF A DIRECTORY C:\TEMP EXISTS, A FILE "LOG" WILL BE CREATED IN IT THAT LOGS WHERE NANS ARE ORIGINATING. Please send me that file after a NAN error.
OLDER CHANGES:
- New skin
- Fix Basstardizer crash
- Fixed Symmetric Peak
- Max release speed fixed
New AGC mode MORE INFO BELOW!
- RDS: Add PTYN
- RDS: Add timeout for TA
- VST version no 4K
- Backup input - check stereo
- Self test crashes
- Put Bass EQ under license
- Added Basstardizer
- Add low input level warning
- Added ASIO latency setting.
- NAN in equalizer fixed
- Sound card high frequency correction: Make sure it always works.
- Quality > 100% extreme CPU warning and recovery
- Quality > 100% Bypass switching causes buffer filling to move
- Decide RW ad?
- Add AM presets
- Add new presets
- NAB stuff
- Cc
- Kant
- AGC better LKFS (Bojcha)
- Classical preset
- Test NanoPi
- AM streaming output
- Multi-instance version
- AF method B via UECP
- 18 Hz trigger tone
- Declipper check L-R effects
- Reduce extreme stereo
- Check out Butt
- Omnia.9 test/fix logging
- WatchCat website
- Triple stuff
- uMPX 24x2ch interface
- One bass page
- Talk to chip
- 2 jaar
- Fardau
- -24 dB side chain range?
NOTE: Bass EQ
New compressor mode info:
PostPosted: Sun Apr 01, 2018 7:21 pm
I agree, but it was to experiment.
PostPosted: Sun Apr 01, 2018 7:25 pm
Hello Hans,
Translation problem
I can't translate the following lines:
Prepare for lossy compression (MP3/AAC/OGG/...)
Input can be compressed (MP3 etc.)
PostPosted: Mon Apr 02, 2018 12:14 pm
Stereo Tool 8.55 BETA058
NAN LOGGING VERSION - BE CAREFUL WHEN USING FOR PRODUCTION! If a NAN occurs AND a directory C:\temp exists, this version will log a lot of data to a file C:\temp\log - during the logging the processing may have severe hiccups. If you have non NAN error problems, this version will run normally, just a bit slower. If non NAN's are reported today I will remove this again!
Windows stand alone: http://www.stereotool.com/download/ster ... 55-058.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 55-058.exe
VST: http://www.stereotool.com/download/vst_ ... 55-058.dll
OLDER CHANGES:
- New skin
- RDS: Add PTYN
- VST version no 4K
- Self test crashes
- Decide RW ad?
- Add AM presets
- Add new presets
- NAB stuff
- Cc
- Kant
- Classical preset
- Test NanoPi
- Check out Butt
- WatchCat website
- Triple stuff
- One bass page
- Talk to chip
- 2 jaar
- Fardau
NOTE: Bass EQ
