Post new topic  Reply to topic  [ 1012 posts ]  Go to page Previous 143 44 45 46 47102 Next
PostPosted: Fri Feb 15, 2013 5:15 pm
I don't think there's any need for 5 interface modes, maybe 2 or 3 will do.
+1
Will keep the 5 modes for now, and later check the differences between the modes to determine if some can be removed. When describing the different modes I had difficulty describing the difference between Advanced and Expert so it probably makes sense to combine those.
Simple mode is useful for people who really don't know what they are doing.
Basic mode should be good for the average user who knows other audio processors and quickly wants to get started with Stereo Tool.
Advanced and Expert... I don't know.
Extreme Tweaker - contains settings that normal people should never need to use, people have already suggested hiding these settings behind a password. Contains things like multiband band frequencies and steepness etc.
PostPosted: Fri Feb 15, 2013 5:29 pm
+1
Hans,
I agree with you.
paragraphic is much more simple and intuitive
PS. bass boost, no longer needed, with the equalizer, much better results and no artifacts.
PostPosted: Fri Feb 15, 2013 5:32 pm
It doesn't do the same thing as the equalizer - but I think the Bass Shape section in the clipper does a much better job than Bass Boost, so it might indeed be a candidate for removal.
PostPosted: Fri Feb 15, 2013 5:43 pm
As for EQ.. now with better scale it's bit difficult to 'draw' shape for lower frequencies.
3 or 4 bands are more then enough..
One of simplest PEQ but also very good quality with fully phase linear is http://www.liquidsonics.com/software_filtrate.htm
3 sliders per band (as any other PEQ)
With this EQ i can even make awesome HPF :)
PostPosted: Fri Feb 15, 2013 5:54 pm
Hans,
I tried to advanced clipper - bass shape, no good result, rather well with eq. (see photo)
http://i.imgur.com/d115g9C.gif
PostPosted: Fri Feb 15, 2013 5:57 pm
great, as always Bojcha, this would be a perfect solution.
PostPosted: Fri Feb 15, 2013 6:28 pm
Bojcha , Hans know what is the problem ..
I always use the RMS option. But you said was fixed. No it`s not.
Both Monitor option in MB and Bass Boost with Difference presents this "blop blop"
In different songs this "blop" is different bad :)
And yeah there is from 39 to 40 beta increase about 5-6 % CPU power. But from beta without new MB to now it`s about 10-12% at all.
PostPosted: Fri Feb 15, 2013 6:30 pm
Yes Yes Yes!! That's is what I meant.
Way and way easier then drawing
The Power of Sound
PostPosted: Fri Feb 15, 2013 6:34 pm
Well... i almost don't hear it with RMS (beta039).. also it actually has bit less artifacts then listening on monitor.
PostPosted: Fri Feb 15, 2013 6:38 pm
No, because internally I would still have to convert it to a graph like this - with yes same issues. Do you need steeper slopes for low frequencies?
