Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 758 posts ]  Go to page Previous 143 44 45 46 4776 Next
PostPosted: Sat Mar 31, 2018 11:16 am
Thank you Hans :)
PostPosted: Sat Mar 31, 2018 11:26 am
Thank you Hans :)
Fixed! Will be fine in the next build. You don't have to change your file, it will just work in the next one.
PostPosted: Sat Mar 31, 2018 11:31 am
Thanks hans, I take this opportunity to ask you if the integration of my translation of the.stl file could be taken into account for the final version.
PostPosted: Sat Mar 31, 2018 3:36 pm
Latest beta does nt start...! I run it and it closes without any warning... cant run.
rollback beta55.
PostPosted: Sat Mar 31, 2018 3:38 pm
Hi Hans, I have found a bug:
Since this Beta56 The dsp_stereo_tool.dll 32Bit crashes with Winamp v.5666 Build3516
When I start Winamp following happens:
1.The Winamp setup appears for two seconds.
2.Then the Winamp Setup calls Reporter.exe (Winamp Error Feedback Reporter) in Winamp Plugin Directory for three seconds. After that winamp closes itself.
When I change dsp_stereo_tool.dll Beta56 to the old one Beta55 or earlier all works fine.
PostPosted: Sat Mar 31, 2018 3:41 pm
I have a problem with Bass EQ. I have made a preset with bass eq activated. If I try to load the bass eq settings into another preset (LOAD / BASS EQ SETTINGS), they will not load. I've had this issue with previous beta versions too (standalone, W10 64bits).
Ah. Oops. It was changing Auto EQ instead. Fixed. (Next beta)
Hi. I still have this problem with the latest beta :(
PostPosted: Sat Mar 31, 2018 6:50 pm
rollback beta55.
Which version are you running exactly? Can you send me your full settings file ("EXPORT ALL")? Please send it via a PM, or mail to mail@hansvanzutphen.com
It doesn't crash here, unfortunately. Can you send me your full settings file ("EXPORT ALL")? Please send it via a PM, or mail to mail@hansvanzutphen.com
PostPosted: Sat Mar 31, 2018 11:53 pm
I'm also having an issue with 056 in WinAmp v5.65, exactly the same as Eldorado.
All other earlier dsp versions work fine, but when clicking to choose 056, it crashes my WinAmp immediately.
PostPosted: Sat Mar 31, 2018 11:54 pm
I just got a message from Bojcha that it crashes on XP, and I tested that and that happens here too. So that's good news, since now I can reproduce it.
I'm trying to fix it tonight.
Looks like the NAN fix worked (according to Bojcha on a Windows 7 system where everything works fine), but broke compatibility with older CPU's and Windows XP. :(
