Post new topic  Reply to topic  [ 752 posts ]  Go to page Previous 142 43 44 45 4676 Next
PostPosted: Sat Oct 27, 2012 4:34 am
Stand alone: http://www.stereotool.com/download/ster ... 33-029.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 33-029.exe
VST: http://www.stereotool.com/download/vst_ ... 33-029.dll
Done:
- Optimize text display code (place_zoomed_text_new, using LUT, similar to scopes)
- Fix button click behavior (button must be deactivated, focus must be restored when closing registration window)
- Vertical volume bar showed 32 dB instead of 30
- Too big spaces removed
- 2 rows visible at height 768
- Left menu changed; separated Configuration from Processing and moved both to top level.
Question: Should I move Configuration to the bottom?? Or even move the one that's not active to the bottom?
- Left menu maximum width reduced
- Changed width of MPX signal display
- BS412 display updates did not always occur in the BS412 panel.
- PHASE ROTATION BROKEN AT LOW LATENCIES
- Remember old location in left menu per section. So if you open Processing you go back to Processing -> Stereo -> AZIMUTH for example. Or would that be annoying? You might expect to go to Processing overview screen...
- Add bandpass, FM (via MPX panel!), latency/quality and maybe sound cards to bottom display.
- Clean up button bar (remove some things and move to Configuration view?)
- What to do with FM settings? Move to config?
- Check crash in command line version (in Enabled refresh function - probably related to loaded parameters - is that even possible? Cannot reproduce it anymore...)
- Pull-down scroll bar appears when it's not needed
- After scrolling with scroll bar, mouse hover doesn't work anymore
- Implement mouse wheel and cursor keys for sliders
- And a warning in the buttons bar if unregistered options are in use, or change 'Register' button color.
- Display last loaded preset name, if possible also with whether it has been changed and keeping it on restart
- Same for new version alerts.
I think I can put both between the buttons in the button bar if the screen is wide enough, if not I can put it above the button bar in the section above it isn't too big. Not sure if that's a good idea though, maybe I need to do something else instead (for example combine buttons such as Help and About if the screen isn't wide enough).
Less urgent for usability:
- Design (several people are working on something)
For later:
- Multi-language support
- Add basic/advanced modes
PostPosted: Sat Oct 27, 2012 3:00 pm
Some mess in Soundcards > Input
PostPosted: Sat Oct 27, 2012 4:40 pm
Yep, confirm the mess :)
PostPosted: Sat Oct 27, 2012 11:55 pm
Mess fixed.
I just discovered that phase rotation is broken at lower latencies (1024 and 512), probably also in version 6.32! So avoid it for now...
PostPosted: Sun Oct 28, 2012 1:38 pm
Few usability improvements (you can now click on volume meters to go to the volume settings)
I think I fixed a bug in the clipper, which may have some effect on the audio (?).
Natural Dynamics can be enabled by changing the setting OVERRIDE_ShowNaturalDynamics to 1.
Stand alone: http://www.stereotool.com/download/ster ... 33-030.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 33-030.exe
VST: http://www.stereotool.com/download/vst_ ... 33-030.dll
- Fix OVERRIDE_ShowNaturalDynamics loading/saving
- Check crash in command line version (in Enabled refresh function - probably related to loaded parameters - is that even possible?)
- Implement mouse wheel and cursor keys for sliders.
- Find 3 memory leaks
- Remember old location in left menu per section. So if you open Processing you go back to Processing -> Stereo -> AZIMUTH for example. Click on Processing again (if it's already open) and you go to the Processing screen. - did it only for 2 top levels but I think this makes more sense.
- Disable Airy Highs if there are very little highs - need to do final test to confirm that it doesn't hurt other sounds
- Fix declipper click issue - greatly reduced
- Check hangup - not seen anymore, may have been caused by old pull-down menu implementation.
- Mouse shape
For later:
- Confirm on close (stand alone version)
PostPosted: Sun Oct 28, 2012 1:54 pm
BAD.. ?
What is so bad ? Or what is goin bad ?
PostPosted: Sun Oct 28, 2012 3:28 pm
BAD.. ?
I had uploaded an earlier BETA030 and it sounded horrible (something was broken) - so I replaced the post by 'BAD' - indeed very unclear if you didn't see it before
Now there's a new version 030 - I'm curious if anyone hears a difference? The bug fix should (but probably VERY slightly) affect the Loudness filter, and mainly the bass clipper in it.
PostPosted: Sun Oct 28, 2012 8:45 pm
In which section do I need to enforce this setting. I created a new copy of sts file (from VST plugin). The new file does not have this parameter. I tried inserting the parameter in [Stereo Tool Configuration] and [Natural Dynamics] sections. Don't see it in UI yet...
Another thing - in previous version of sts files, settings for Attack(Down-speed) and Release (Up-speed) were swapped wrt to UI. I raised this request, if you remember, to rectify.
For the sake of not making older presets obsolete, you said you'll get it fixed with the UI revamp.
Can I expect this happening now?
Attack speed - Band 7=0.00005
Decay speed - Band 7=0.0009
visit website
PostPosted: Sun Oct 28, 2012 9:27 pm
I see that the exact name is "OVERRIDE: ShowNaturalDynamics" - and it's under [Stereo Tool Configuration] indeed.
About the change of attack and decay: Currently the .STS files are still nearly completely compatible with earlier versions (AGC bands and a few Stereo Image settings are different). So I think it's best to leave it as is for now...
PostPosted: Sun Oct 28, 2012 10:06 pm
i can't see OVERRIDE ShowNaturalDynamics
