Post new topic  Reply to topic  [ 1012 posts ]  Go to page Previous 142 43 44 45 46102 Next
PostPosted: Fri Feb 15, 2013 2:27 pm
Solved. Also fixed that part of the bars were not redrawn in 1-channel mode. (Still remaining: The 2nd channel stays at the last position when you play 1-channel audio.)
That is displayed - they light up brighter, same as clipping in the old MB.
Strange they are working now with the preset from Bojcha that i'm testing. Before it didn't displayed them.
Found it: It's not displayed with samplerate of 192 kHz.
Will also check[/color]
PostPosted: Fri Feb 15, 2013 2:28 pm
Still no sound in VST Version in Adobe Audition 3.0. This is really strange. :roll:
Is this still the case?
PostPosted: Fri Feb 15, 2013 2:43 pm
may be for the "blob blob" effect on the both places you use same code for the two filters and the effect is the same .. must look into it , because the bass is not clear this way. But i know you will find the bug for this ringing on a bit higher frequencies after the bass.
You already are nominated for President :)
PostPosted: Fri Feb 15, 2013 3:12 pm
Hans,
you're doing an amazing job, you are a special person, and I thank you immensely, because even a small radio stations like mine, it allows you to have a great sound. thank you, thank you, thank continues.
PS. the new multi-band, great sound! :P
PostPosted: Fri Feb 15, 2013 3:55 pm
Doggy, try rms mode for bands.
PostPosted: Fri Feb 15, 2013 4:00 pm
No there's really a weird sound in Bass Boost. More noticeable if you use DIFF - so it's probably not THAT much of an issue.
PostPosted: Fri Feb 15, 2013 4:45 pm
Everythinh is working fine for me in terms of usabillity except for the equalizer. Drawing it, is not for me.
Maybe - I'm just sugessting something and could be completly wrong - to be in the same usabillity of all the other things it could be with normal sliders etc like this
you want to equalize the 150hz with 10db
then there should be a slider like this:
''box1'' 100 hz ''box2'' 200hz ''box3'' 10db
or
box1'' 140hz box2'' 160hz box3'' 10dB
The numbers you put in box 1 and 2 determine the ''angle'' off the ''boost''.
so the middle of the 2numbers is the one you want to equalize, and the other numbers determine the steepness
and then something like 10 band equalizer with amount of band being adjustable.
I hope it's clear what I mean......
The Power of Sound
PostPosted: Fri Feb 15, 2013 4:51 pm
Ah, i though on MB bands (but that's also fixed now in b40). Yes, Bass boost has those artifacts from long time ago. Luckily i will never use it anymore :)
PostPosted: Fri Feb 15, 2013 5:07 pm
I'm measuring a 20% total CPU load increase when using the new MB vs. the old one, and that's based on 5 bands. With 9 bands it's even 45%. So I guess I need to try to optimize it (the singleband compressor, which is the cause of the increase) a bit more.
Ah, due to the improvements I did earlier the difference with version 7.03 is smaller than this:
- 11.5% for 5 bands
- 24% for 9 bands
Not great, but not as bad as it seemed to be. But there must be some opportunities for improvement (among others, simplify the signal level analysis method).
PostPosted: Fri Feb 15, 2013 5:12 pm
There are more people who are saying this. To me, drawing is much easier than having to set a whole lot of siders - you can easily make *any* frequency response that you like, without having to think how separate bands of a parametric equalizer will affect each other etc. It also resembles a lot how you can eq a file in CoolEdit for example (although you have to set points there, it's not freeformat drawing).
So I'm curious what others think...
