Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 758 posts ]  Go to page Previous 142 43 44 45 4676 Next
PostPosted: Thu Mar 29, 2018 3:39 pm
Hans,
There was a post on Facebook a bit ago that mentioned noise/artifacts being caused by the Declipper. You said you were excited to look into that since you hadn't heard of any issues with Declipper in quite a while. Is that still on your roadmap for this release?
Not for this release. I have put it on the todo list.
Foobar no longer crashes when changing settings in beta 052... ;) surround full open what a wonderful sound this version is able to create!
Weeeh ;)
PostPosted: Fri Mar 30, 2018 4:50 am
Hans,
The fact that nobody is reporting NAN's anymore, does that mean that they no longer occur?
The one I reported is fixed. Running fine now.
C.
PostPosted: Fri Mar 30, 2018 9:57 am
Stereo Tool 8.55 BETA055
NAN LOGGING VERSION - BE CAREFUL WHEN USING FOR PRODUCTION! If a NAN occurs AND a directory C:\temp exists, this version will log a lot of data to a file C:\temp\log - during the logging the processing may have severe hiccups. If you have non NAN error problems, this version will run normally, just a bit slower.
Windows stand alone: http://www.stereotool.com/download/ster ... 55-055.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 55-055.exe
VST: http://www.stereotool.com/download/vst_ ... 55-055.dll
- TURNED NAN LOGGING ON - IF A DIRECTORY C:\TEMP EXISTS, A FILE "LOG" WILL BE CREATED IN IT THAT LOGS WHERE NANS ARE ORIGINATING. Please send me that file after a NAN error.
OLDER CHANGES:
- New skin
- Fix Basstardizer crash
- Fixed Symmetric Peak
- Max release speed fixed
New AGC mode MORE INFO BELOW!
- RDS: Add PTYN
- RDS: Add timeout for TA
- VST version no 4K
- Backup input - check stereo
- Self test crashes
- Put Bass EQ under license
- Added Basstardizer
- Add low input level warning
- Added ASIO latency setting.
- Quality slider extended to 150%
- Tera
- Hard Limit apparently sounds bad again :(
- Sound card high frequency correction: Make sure it always works.
- Quality > 100% extreme CPU warning and recovery
- Decide RW ad?
- Add AM presets
- Add new presets
- NAB stuff
- Cc
- Kant
- AGC better LKFS (Bojcha)
- Classical preset
- Test NanoPi
- AM streaming output
- Multi-instance version
- AF method B via UECP
- 18 Hz trigger tone
- Declipper check L-R effects
- Reduce extreme stereo
- Check out Butt
- Omnia.9 test/fix logging
- WatchCat website
- Triple stuff
- uMPX 24x2ch interface
- One bass page
- Talk to chip
- 2 jaar
- Fardau
- -24 dB side chain range?
NOTE: Bass EQ
New compressor mode info:
PostPosted: Fri Mar 30, 2018 1:20 pm
Congratulations Hans, with the new configuration of the compressor has taken a giant step. It sounds really good now.
But, for my ears, I only hear well in beta 28. Especially the highs. Even in mp3!
From beta 28 I hear very screaming.
As someone said before, I think he should patent the new configuration. He has changed the sound a lot.
In lost files, it no longer sounds like "phone".
Pretty Girls in your city
PostPosted: Fri Mar 30, 2018 4:28 pm
Are you saying 028 sounds good and 030 doesn't? Can you send me your settings so I can check? According to the change log there shouldn't be any audio changes between those two.
PostPosted: Fri Mar 30, 2018 6:31 pm
I currently use music from the 80s. Mixed in Pacemaker Editor (a great program to mix music in a very easy and entertaining way).
But only allow to save in ogg 192 Kbps Vbr 44,100 Hz.
https://www.youtube.com/results?search_ ... ker+editor
First process with st the preset of: Jesse Graffam - Minnesota Lakes v0.01.57 HD.
Saved in Wav 48,000 Hz.
Second, I re-process with st and the Phoenix preset - Orban 8600 Impact MX and with natural dynamics activated.
I do both processes in beta 028.
In the following betas, it does not sound the same. :shock:
PostPosted: Sat Mar 31, 2018 10:16 am
Stereo Tool 8.55 BETA056
I *may* have found the cause of the NANs. And fixed it.
Windows stand alone: http://www.stereotool.com/download/ster ... 55-056.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 55-056.exe
VST: http://www.stereotool.com/download/vst_ ... 55-056.dll
OLDER CHANGES:
- New skin
- RDS: Add PTYN
- VST version no 4K
- Self test crashes
- Tera
- Quality > 100% Bypass switching causes buffer filling to move
- Decide RW ad?
- Add AM presets
- Add new presets
- NAB stuff
- Cc
- Kant
- Classical preset
- Test NanoPi
- Check out Butt
- WatchCat website
- Triple stuff
- One bass page
- Talk to chip
- 2 jaar
- Fardau
NOTE: Bass EQ
PostPosted: Sat Mar 31, 2018 10:53 am
Hello Hans,
Translation problem
I can't translate the following lines:
Step size reduction (higher = better hiss restoration; increases CPU load).0=?????
1 band (off = 160)=?????
nothing is displayed in french
PostPosted: Sat Mar 31, 2018 11:11 am
Hello Hans,
Translation problem
Ah, and I see why - there are 2 = signs on those lines, one in the text itself. Will put it on the todo list.
