Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 141 42 43 44 4559 Next
PostPosted: Sat May 07, 2016 1:17 pm
By the way, this seems to happen so infrequently that I wonder if it's a real concern. It's also possible it's not just the latest beta.
This isn't new - I've seen this many times during at least a year. I know what causes it but never bothered to fix it...
PostPosted: Tue May 10, 2016 4:24 am
BEEP!
BEEP!
BEEP!
PostPosted: Wed May 11, 2016 12:42 pm
Come on , enough with this beeps crying .
This version of ST with new features is NOT official released , it`s on test/developing period and Hans can`t do it all for 2 hours or for 2 minutes. Just wai tfor a while and all will be good enough. Hans cannot put price or to write in price page something that is not tested long enough and not official released, damn. Come on, be at least respectful to the Hans`s work.
When the release is ready, then all of you will have the ability to buy what you want .
Also, you are NOT recommended to use the unofficial beta versions in real operation ! Just for testing.
PostPosted: Wed May 11, 2016 6:45 pm
Just that right there :) and it's not the worst idea ever to wait for 1-2 months for someone else to test the released version for you too.
Slow down, and enjoy the ride 8-)
PostPosted: Wed May 11, 2016 8:57 pm
Guys & girls sorry I was just trying to be funny.
Hans stated in a previous post to remind him about it.
That was all.
Sorry, won't happen again.
PostPosted: Thu May 12, 2016 12:24 am
I need to update my scripting to handle payments automatically, without that I would have to check every order manually to match it with an existing license and update that.
On the normal payment page, it doesn't make sense yet to offer it because there's no release available that contains it. And I think I really need to rework the payment page now, because with the Delossifier added I will have twice as many license types - without some way to guide people through the different options it's going to be way too confusing.
I can easily put a button here with which you can pay a license, but my scripting here needs to be able to handle it as well.....
PostPosted: Thu May 12, 2016 12:28 am
Hans - it's cool.
I'm sorry I thought I was being a bit humorous but it appears all I've done is upset people.
Worrying about the license is the last thing to be concerned about! I don't mind at all!
*pops head down and shuts up*
PostPosted: Fri May 13, 2016 5:16 am
7.85 BETA069
Windows stand alone: http://www.stereotool.com/download/ster ... 85-069.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-069.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-069.dll
CHANGED:
- Option added to allow Quadrature noise, this allows about 0.1-0.2 dB extra loudness (and a more open and less distorted sound) through the clipper. Might have some negative effects on stereo separation though on certain radio's (although it shouldn't be worse than some other processors' default behavior).
- Fixed logged out mode (needs to be updated for newly added pages and settings)
- Finalized RDS HTTP commands (Arctic Palm) - wait for test results.
- Crashes sometimes (since 061). -> Appears to be solved.
- Fixed 16/24 bit LSB ASIO format for new AudioScience 192 kHz capable sound card. - Matt Levin will test
- Add RDS HTTP commands (Nashville - talk to Arctic Palm) - Partially done - Arctic Palm will test
- Crash in Delossifier
- HD: Label "Diversity Delay" & add "HD" label to streaming
- Bass AGC (Old) is broken! -> Oops, new Ratio was implemented but it had a 1000:1 ratio instead of 1:1000!
- OPTIMIZE DELOSSIFIER
- Reduced stack usage, hopefully fixes crash issue
- Fix AGC ratio display
- Absolute Highs: Optimize performance: Check log() -> Removed most (256 to 40 per step), and part of code that's not needed disabled for Delossifier.
- Exciter: Try to reduce pre-ringing (maybe by doubling overlap? Or measure on bigger block size, then go back to smaller?) Is this still a problem? -> Doesn't seem to be.
- Fixed GUI bug. Maybe that fixes the gray screen that was reported by RadioImInternet - but I'm not too sure about that.
- Bug: Stereo Image Phase to 0 reduces L-R anti-phase sounds by about 6 dB, and also not constant. (This is new, used to be good before!) Problem occurs when feeding 100% anti-phase, even 1 degree difference between channels fixes it completely. -> Effect is reduced now, hopefully acceptable.
- Add Ratio to AGC
- Add Analyzer BYPASS mode (is that needed??) -> No, probably works already, but despite that, we can use a separate PC at the NAB for this.
- All L/R - L/R Quadrature mode, test with noise -> Doesn't work :(
- Add FM phase shift remover for high frequencies for Multipath
- Input Gain issue (see 2 posts below BETA054)
- LW SKIN!
- uM: Filter and add vac1/2/3/... option!
- Fixed broken VST plugin.
- Delossifier: Added MP3 detection filter; turn it on to disable the Delossifier when it thinks that the input is not an MP3.
- Delossifier: Protection added to not add too much. The result sounds cleaner, but it might also be slightly less effective. In total I think it's better.
- Detection and reconstruction both fail in 60's song Lay Down! -> Better now, but: 1. Make sure that this doesn't reduce repair elsewhere (some other parts are better now too, so be careful with that!). Maybe only remove narrow 'gaps' in the xmul array. 2. Improve detection to make Lay Down sound good always. It's not even an MP3! Check not only close to border but also a bit higher - should be nearly perfect silence! Maybe also some slowness in starting to repair?
- Absolute Highs: CRASH!
- Add Quadrature monitoring
- SPA remove monthly popup
- Added other optimizations
- Fix crash in BETA036.
- Exciter: Add Volume slider
- Exciter: Add DIFF mode
- Fixed crash when closing
- GUI: Added tooltips!
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- LW buffer bug - if the Normal Output buffer is small, LW input hangs.
- Try allowing more Quadrature noise.
- Auto-detect wrong sample rate conversions.
- Absolute Highs has pre-ringing/mpeg like artifacts, try smaller block size (I think I increased it at some point to better filter annoying tones but that caused this problem).
- Try Delossifier on L-R??
- Try: Volume difference effect with different speed at different frequencies (From Pre-ringing killer)
- Show band frequencies in GUI (Natural Dynamics, MB).
- Delossifier: Pre ringing killer causes volume bumps. Which seems to sound good!!! Add a feature for this?
- set Encryption : impossible to view or modify all the processing settings. Solution is: Password like there is now (but only on Processing/repair settings!) to unlock viewing the settings plus one to load the .sts file (in the .ini it should load automatically I think...). In both cases, we could point to a separate fle that contains all the encoded settings. In case of .ini the password for unlocking must be stored in the .ini file..
- Preset Licensing : encrypted preset without beeps unlocked by a license - or never visible?
- Clipper on separate CPU for ARM - or move around on cores?
- Normal Output: Don't output FM anymore!
- Absolute Highs: Check how slowly the frequency should rise. Probably should only be available if Delossifier freq responds slowly? (Maybe already ok?)
- Add separate watchdog process - see Zuidwest FM email dd 2016-04-20 12:24
- Delossifier: Lay Down breaks Delossifier, sounds really bad with MP3 detection turned off! (And it's not MP3). More accurate detection (smooth rolloff??) still needed, to also not detect it when not using Detect MPEG mode! Does Alternative Method sound better now?? Also try without HACK.
- OS X update wxWidgets for 10.10.5 compatibility.
- Add HTTP commands and feedback - viewtopic.php?f=16&t=7701&p=34436#p34436
- Add sound card adjustment presets for analog sound cards.
- Input Balance issue (see 2 posts below BETA054), cause known (reallocalte big buffer for waveform display, then buffer size doesn't match, and for some reason this causes a shift in time. However, calculated values appear to be correct. Check in more detail after NAB.)
- License check
- Stand alone program & VST with demo option to do Declipper, Delossifier, AZIMUTH, Dequantizer, PNR, Natural Dynamics. (No noise gate!). Somewhere in next 2-3 weeks. ProTools plugin without demo. Maybe run limited time and stop. Or announcement every 25 seconds.
- O skin
LATER:
- Clipper: Try pre-filling quadrature! Put in pilot_rds signal. What about BS412?
- Add RT+ and Arctic Palm-like formats to help page
- Add auto detection of certain sound cards, like Marian Trace Alpha.
- Check Sort algorithm optimization
- Make DIFFERENCE work in Natural Dynamics for separate bands
PostPosted: Fri May 13, 2016 6:22 am
7.85 BETA069
Loads then shuts down.
Exception code: 0xc0000005
Fault offset: 0x00eb8e60
Faulting process id: 0x16c4
Faulting application start time: 0x01d1accf2c14789f
Faulting application path: C:\Program Files (x86)\Stereo Tool\StereoTool.exe
Faulting module path: C:\Program Files (x86)\Stereo Tool\StereoTool.exe
Report Id: 69d40e82-18c2-11e6-aae7-782bcb98199f
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2016-05-13T04:23:16.000000000Z" />
<EventRecordID>10427</EventRecordID>
<Channel>Application</Channel>
<Computer>User-PC</Computer>
<Security />
</System>
<EventData>
<Data>StereoTool.exe</Data>
<Data>0.0.0.0</Data>
<Data>57353e77</Data>
<Data>c0000005</Data>
<Data>00eb8e60</Data>
<Data>16c4</Data>
<Data>01d1accf2c14789f</Data>
<Data>C:\Program Files (x86)\Stereo Tool\StereoTool.exe</Data>
<Data>69d40e82-18c2-11e6-aae7-782bcb98199f</Data>
</EventData>
</Event>
C.
PostPosted: Fri May 13, 2016 11:54 am
confirmed... it crash
