Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 758 posts ]  Go to page Previous 140 41 42 43 4476 Next
PostPosted: Tue Mar 27, 2018 9:09 am
Sometimes, when switching from one preset to another, the auto eq freezes up. Generally the highest band gets stuck to its maximum gain, the other bands stay at 0. No message and nothing recorded in the temp folder. I need to close stereotool and launch it again to sort this out.
PostPosted: Tue Mar 27, 2018 9:16 am
Any idea from which to which preset you switched? Your own presets or built-in presets? (I'm asking because all the built-in presets still use Legacy mode).
PostPosted: Tue Mar 27, 2018 9:18 am
There was a bug in the VST loading error that could cause all kinds of weird things when Phase Delay was enabeld in a preset. So that might have been causing bad things to happen...
I think it is something related to display / graphics. The reason I believe this is the fact Linux Mate accepts 8.23 and needs Xorg and GDM3 after 8.54. Windows version drops all display on our side on mouse operations and has a tremendous increase of problems when other layered windows are below / under Foobar and ST.
Hm, I didn't really change anything in the GUI part (and there should be no difference on Linux between 8.23 and 8.54 as far as I remember either!). Can you give me more details? I'm not seeing any issues here - but I could very well be missing something.
PostPosted: Tue Mar 27, 2018 9:21 am
Last time it happened I was switching from a home made preset (using 4 bands for auto eq) to Blue Steel.
PostPosted: Tue Mar 27, 2018 9:31 am
Stereo Tool 8.55 BETA052
NAN LOGGING VERSION - BE CAREFUL WHEN USING FOR PRODUCTION! If a NAN occurs AND a directory C:\temp exists, this version will log a lot of data to a file C:\temp\log - during the logging the processing may have severe hiccups. If you have non NAN error problems, this version will run normally, just a bit slower.
Windows stand alone: http://www.stereotool.com/download/ster ... 55-052.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 55-052.exe
VST: http://www.stereotool.com/download/vst_ ... 55-052.dll
- TURNED NAN LOGGING ON - IF A DIRECTORY C:\TEMP EXISTS, A FILE "LOG" WILL BE CREATED IN IT THAT LOGS WHERE NANS ARE ORIGINATING. Please send me that file after a NAN error.
OLDER CHANGES:
- New skin
- Fix Basstardizer crash
- Fixed Symmetric Peak
- Max release speed fixed
New AGC mode MORE INFO BELOW!
- RDS: Add PTYN
- RDS: Add timeout for TA
- VST version no 4K
- Backup input - check stereo
- Self test crashes
- Put Bass EQ under license
- Added Basstardizer
- Add low input level warning
- Added ASIO latency setting.
- Aanvraag uren
- Fix multi-threading switching problem. (Separate instances for separate locations, but that might not be all? How can it fail just after increasing the number of threads?) [THURSDAY]
- Quality slider extended to 150%
- Check reported silence error - Maybe fixed?
- Does ACR DIFF mode cause NAN's?
- Add AM presets
- Add new presets
- NAB stuff
- AGC better LKFS (Bojcha)
- Classical preset
- Test NanoPi
- AM streaming output
- Multi-instance version
- AF method B via UECP
- 18 Hz trigger tone
- Declipper check L-R effects
- Reduce extreme stereo
- Check out Butt
- Omnia.9 test/fix logging
- WatchCat website
- Triple stuff
- uMPX 24x2ch interface
- One bass page
- Talk to chip
- 2 jaar
- Fardau
- -24 dB side chain range?
NOTE: Bass EQ
New compressor mode info:
PostPosted: Tue Mar 27, 2018 9:32 am
And is your home made preset using Legacy mode?
PostPosted: Tue Mar 27, 2018 9:40 am
Yes !
PostPosted: Tue Mar 27, 2018 12:00 pm
Yes !
Weird. This *should* be caused by a NAN error... But then why didn't it show up, and why is there no file in C:\temp? :(
I'll try to reproduce it after lunch...
Might have found it...
PostPosted: Tue Mar 27, 2018 5:16 pm
It would be really great for editioned/split stations to be able to turn off AF Frequencies (or fill/edit them) from MagicRDS.
I don't understand why there is any need for a UDP Protocol for UECP/MagicRDS. Can you tell Hans?
PostPosted: Tue Mar 27, 2018 6:33 pm
There are programs that use UECP via UDP, and so we needed to support that.
AF -> Do you mean AF method A or B? You're the first to request this (I know it's useful, but as long as nobody asks it makes no sense to spend time on it).
