Post new topic  Reply to topic  [ 707 posts ]  Go to page Previous 139 40 41 42 4371 Next
PostPosted: Tue Apr 11, 2023 7:11 pm
Stereo Tool beta 066... I can say that now the preset selection works great with screen readers. Great work for you. Thank you.
PostPosted: Sun Apr 16, 2023 11:50 pm
Version 066 VST2 plugin opens slowly and AGC stereo section is missing.
PostPosted: Tue Apr 18, 2023 12:56 pm
Beta 10.02-066 64 bit jack stand alone doesn't start:
./stereo_tool_jack_gui_64_BETA1002-066
Thimeo Stereo Tool 10.02 BETA066 (for Linux with Jack) (C) Thimeo Audio Technology, 2001-2023
ALSA lib pcm_dmix.c:1089:(snd_pcm_dmix_open) unable to open slave
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm_route.c:869:(find_matching_chmap) Found no matching channel map
ALSA lib pcm_oss.c:377:(_snd_pcm_oss_open) Unknown field port
ALSA lib pcm_usb_stream.c:486:(_snd_pcm_usb_stream_open) Invalid type for card
ALSA lib pcm_hw.c:1829:(_snd_pcm_hw_open) Invalid value for card
ALSA lib pcm_direct.c:1824:(_snd_pcm_direct_get_slave_ipc_offset) Invalid value for card
Segmentation fault (core dumped)
An earlier beta 10.02 BETA035 does start.
PostPosted: Tue Apr 18, 2023 1:01 pm
10.02 BETA035 Jack 64bit (testing with an older beta as the latest doesn't run)
This problem is also found in the latest stable, 9.92 and is observed here by another user:
viewtopic.php?f=2&t=33439
FM and normal output can't be used together.
No audio ever comes out of fm_l and fm-r.
The only way to get FM output is to turn off normal output so it comes out of out_l and out_r.
Also jack isn't mapped to route FM output to the correct destination.
PostPosted: Sun Apr 23, 2023 7:02 pm
Is the Simple Clipper being discontinued?
In the latest betas it shows up as a deprecated setting, when I turn it off it goes away. I had to turn on the feature for showing deprecated settings.
If it's too good of a feature to offer for free, can the volume of the presets be turned down somewhat so that when no clippers are on the audio won't clip/distort for being too loud for the soundcard?
PostPosted: Mon Apr 24, 2023 8:36 am
If I recall correctly:
If the advanced clipper is enabled, it will override the simple clipper in every way.
With the advanced clipper turned off, the simple clipper should reappear.
PostPosted: Mon Apr 24, 2023 5:58 pm
Weird, not for me.
Can the Simple Clipper be made to allow itself to get louder? Maybe 250% instead of just 150. With some presets it has little effect because they're quiet.
I went back to the last stable release, started using Stereo Tool on a 64 bit Raspberry Pi and not sure if there's a beta for that currently. The one on the 1st post appears to be only 32 bit and didn't work.
PostPosted: Mon Apr 24, 2023 8:41 pm
Weird, not for me.
I would actually love it if the Simple Clipper drive was surfaced without needing to disable the Advanced Clipper (either in Quick Adjust or a potential Clipping Overview page, or nested inside the Advanced Clipper page if enabled). The drive of the simple clipper affects the loudness of the advanced clipper if not set to 100%. This is handy as an overall 'volume' control, and it would be amazing if the volume buttons on a media keyboard controlled it. Maybe that's something I could figure out with AutoHotKey and the web interface otherwise.
However, I suspect this is going to be left to the drive and output level of the wideband compressor until this wish is fulfilled.
PostPosted: Mon May 01, 2023 4:06 pm
I think the developers are busy a lot lately. It's been a couple weeks since the last update.
PostPosted: Mon May 01, 2023 6:01 pm
I know there was a convention many time zones away in America. They probably spent a while prepping, a week doing the convention, and likely another adjusting to jet lag. I bet we'll see more updates this week.
