Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 758 posts ]  Go to page Previous 139 40 41 42 4376 Next
PostPosted: Fri Mar 23, 2018 5:26 pm
I’ll try to find something harder :D
PostPosted: Sun Mar 25, 2018 8:33 am
Meaning we will now have to choose between either mode? i.e. You cannot use both at the same time?
PostPosted: Sun Mar 25, 2018 10:58 am
Well, unless you have a good reason to use both at the same time, then I could support that too. But, they both have the same goal, I just think that Basstardizer is a lot better at it than Bass Boost was...
PostPosted: Sun Mar 25, 2018 11:02 am
Stereo Tool 8.55 BETA051
NAN LOGGING VERSION - BE CAREFUL WHEN USING FOR PRODUCTION! If a NAN occurs AND a directory C:\temp exists, this version will log a lot of data to a file C:\temp\log - during the logging the processing may have severe hiccups. If you have non NAN error problems, this version will run normally, just a bit slower.
Windows stand alone: http://www.stereotool.com/download/ster ... 55-051.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 55-051.exe
VST: http://www.stereotool.com/download/vst_ ... 55-051.dll
- TURNED NAN LOGGING ON - IF A DIRECTORY C:\TEMP EXISTS, A FILE "LOG" WILL BE CREATED IN IT THAT LOGS WHERE NANS ARE ORIGINATING. Please send me that file after a NAN error.
OLDER CHANGES:
- New skin
- Fix Basstardizer crash
- Fixed Symmetric Peak
- Max release speed fixed
New AGC mode MORE INFO BELOW!
- RDS: Add PTYN
- RDS: Add timeout for TA
- VST version no 4K
- Backup input - check stereo
- Self test crashes
- Put Bass EQ under license
- Added Basstardizer
- Add low input level warning
- Added ASIO latency setting.
- Aanvraag uren
- Quality slider extended to 150%
- Check reported silence error - Maybe fixed?
- Does ACR DIFF mode cause NAN's?
- Add AM presets
- Add new presets
- NAB stuff
- AGC better LKFS (Bojcha)
- Classical preset
- Test NanoPi
- AM streaming output
- Multi-instance version
- AF method B via UECP
- 18 Hz trigger tone
- Declipper check L-R effects
- Reduce extreme stereo
- Check out Butt
- Omnia.9 test/fix logging
- WatchCat website
- Triple stuff
- uMPX 24x2ch interface
- One bass page
- Talk to chip
- 2 jaar
- Fardau
- -24 dB side chain range?
NOTE: Bass EQ
New compressor mode info:
PostPosted: Sun Mar 25, 2018 4:48 pm
delete
https://maasstad.online/
PostPosted: Sun Mar 25, 2018 8:03 pm
Also Wavosaur
It has a VST rack. :)
Tnxs, we use Wavosaur for batch processing, it responds in real time exactly the same as Foobar to the newest beta.
If we load 8.23 everything works flawless on Wavosaur and Foobar. On Audacity I just tested 8.23 that produced another problem then the so called "hickups". Forget about Audacity it seems to work for tens of millions of people unfortunately not in this instance and I just read this is probably because of their software, so we will not use this anyway.
We use Foobar for testing at least since 7.84 without any problem and even today all these previous versions work ok. Today I updated drivers to be sure, nothing changed. Next week we plan a different fresh Windows setup on a newly installed node using Windows 8 or 7. I do not trust Windows 10 and it's drivers that seem to be causing this. If that doesn't work either we take a break in Stereotool updates till these things that cannot be replicated are fixed by somebody somehow somewere on some system at a later moment.
PostPosted: Sun Mar 25, 2018 9:31 pm
The Audacity hiccups problem is probably caused by the fact that Stereo Tool uses a higher CPU load, and in bursts. Most VST plugins don't.
I haven't seen the other problem yet, I'm hoping right now that it's related to a problem that someone else reported via PM. He just managed to reproduce it in a way that should make it possible for me to find the cause. It could be something CPU type related. I will try to find and solve the issue asap, and then I hope your problem will be solved as well - but I don't know if it will be.
PostPosted: Mon Mar 26, 2018 6:34 am
Just something to try, to rule out...
Go to C:\Users\USERID\AppData\Roaming\audacity
And delete (back up first if you want) pluginregistry.cfg and pluginsettings.cfg.
Start Audacity, do Effect -> Add / Remove Plug-ins..., click "Select All" button, click "OK" button.
Now see if the issues are still present.
PostPosted: Mon Mar 26, 2018 11:15 am
There was a bug in the VST loading error that could cause all kinds of weird things when Phase Delay was enabeld in a preset. So that might have been causing bad things to happen...
PostPosted: Mon Mar 26, 2018 6:34 pm
I think it is something related to display / graphics. The reason I believe this is the fact Linux Mate accepts 8.23 and needs Xorg and GDM3 after 8.54. Windows version drops all display on our side on mouse operations and has a tremendous increase of problems when other layered windows are below / under Foobar and ST.
