Post new topic  Reply to topic  [ 45 posts ]  Go to page Previous 1 2 3 4 5
PostPosted: Mon Apr 18, 2016 3:29 pm
63 khz is the optimum modulation for reducing multipath distortion by other transmitters on FM.
With 63 khz you are compatible with all fm recievers in all areas ( high or low recieption areas )
PostPosted: Mon Apr 18, 2016 6:24 pm
I think you should try stokkemask instead of limiting to 63 kHz.
PostPosted: Thu Apr 21, 2016 12:45 am
@Camclone: Do you have any docs that probe that you say about 63 kHz is optimal for all receivers and best for reducing multipath reception?
https://fmfeeling.com
PostPosted: Fri Apr 22, 2016 2:29 pm
JVC car radio recievers are a very good example :)
The only radiostation that plays clear on multipath areas in a specific area in our Island ( of Crete , Greece ) is this :)
If you use advanced clipping and composite clipping , 63 khz for me is the only choice .
( 60 to 63 max )
TOPIC UPDATED AND MOVED HERE :
viewtopic.php?f=14&t=12841
PostPosted: Fri Apr 22, 2016 4:10 pm
hi
where is our preset (sts file) ?
For test it
Thanks
