Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 13 4 5 6 759 Next
PostPosted: Sun Jan 17, 2016 4:40 pm
The requested URL /download/stereo_tool_standalone_installer_BETA785-009.exe was not found on this server.
That's also true for all earlier versions in this thread, what implies that no one ever downloaded them. :shock:
Huh. But I did get feedback from people who tested it. Maybe they got removed afterwards. Checking...
Edit: Ah. The ClamAV virus scanner is giving a false positive:
https://www.virustotal.com/nl/file/b826 ... 452989918/
And when it does my provider automatically deletes the file.
So, download it while you can! It will probably disappear at some point again.
I just tried to download the BETA785-009 update again and the link is still broken.
PostPosted: Sun Jan 17, 2016 6:46 pm
StereoTool.Standalone.v7.85.x86.beta8.and.9
PostPosted: Sun Jan 17, 2016 7:06 pm
7.85 BETA010 - Be fast! (ClamAV is reporting a false positive and my hosting provider uses ClamAV to check for viruses, so these files will probably be removed after some time).
Windows stand alone: http://www.stereotool.com/download/ster ... 85-010.exe or here
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-010.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-010.dll
CHANGED:
- Added some filtering to make sound less 'sandy' (distorted).
- Exciter: Check why it sometimes boosts audio around 10 kHz (?) more than it should (Johnnie Cash) - protection filter appears not to work completely. Compare what happens without protection filter! -> Fixed (more or less)
- Added a soft of exciter (not an FM exciter but something that generates highs). I've placed it (for now) under True Bass, and it cannot be configured yet. Not really sure what to make of it yet, I think I like it but it does sound a bit "rough" sometimes. Note: It can cause pre- and post ringing at higher latency settings (I will fix that later, first want to get a bit of a feeling for what it does).
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- Try "True Bass" for highs -> Probably make a version where different modes (with/without filtering, with better HPF) are tested. Maybe also with multiple bands?? To reduce generated distortion.
- O skin
- Blog post pre-processing
- Blog post MP3 and declipping
PostPosted: Sun Jan 17, 2016 7:50 pm
Why is the VST plugin file almost 5 MB smaller than in the other betas? The beta version 9 had a size of 21450752 bytes. The present has only 15368192 bytes. Somehow that's a little strange.
PostPosted: Sun Jan 17, 2016 8:05 pm
I don`t understand why you care at all ?
Just download and take your tests. Why you care what is the size...
PostPosted: Sun Jan 17, 2016 11:20 pm
Upload error! Will re-upload.
PostPosted: Mon Jan 18, 2016 8:49 am
Highs exciter sounds like very very bad resampling effect.
Urban Junglist
PostPosted: Mon Jan 18, 2016 11:34 am
Oops! I tested it on phone sounds and forgot to restore the original (currently hard coded) parameters!
PostPosted: Mon Jan 18, 2016 12:52 pm
I found that where we have double "same" indicators , for example FM (on the most right side next to the CLIP)
Now, when you chagne bands on MBs or NB and may be Noise gates, you always get one or another indicator thinner than the other.
Try to change only the MB1 bands from 1 to 9 and look to the FM indicators . The one is thicker in certain settings. May be only even number of pixels for thickness to be used ? 10, 12, 14, etc . I guess it sets even number for the one, and odd number for the other . So, that is the difference in the indicators thickness. Is it "bad looking" ?
PostPosted: Mon Jan 18, 2016 5:34 pm
Until when are you going to make the filter configurable?
What I have noticed:
If you have a piece of audio, which rises in the spectrogram of the energy. That is, for example a snare sound. then the transition between the original and the reconstruction is not good. There is then a hard cut between the original and the reconstruction. The same applies the other way around. If you have a signal, which has hardly overtones eg a classical recording, then there is a large hole between the original and the reconstruction. I've attached two pictures of it.
File comment: Hard transition when there is a snare.
File comment: Hole when the Spekteogram decreases from the energy forth.
