Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 50 posts ]  Go to page Previous 1 2 3 4 5
 Post subject: Re: Stereo Tool 7.80
PostPosted: Thu Nov 12, 2015 3:59 pm
Ok, so we can expect a 7.82 today ?
No, I'm flying back home today. I hope tomorrow. Will do some other minor fixes while flying.
PostPosted: Thu Nov 12, 2015 4:20 pm
Fixing bugs at a height where are no bugs :mrgreen:
PostPosted: Thu Nov 12, 2015 5:05 pm
O, yes - now that`s a fixing, man :) it`s a kind of art
PostPosted: Thu Nov 12, 2015 5:52 pm
Hi! What is happening when you watch FM Transmitter page? There is an individual composite graph display (showing absolutely correct though) which might be causing something weird to the main oscilloscope, the output oscilloscope is like showing interleaved signal but scrolling twice as fast. Any other page shows correct. This is not new though, I just haven't reported this for some reason :D Naturally this requires the FM parts to be enabled.
Edit: 100th post! Yay!
PostPosted: Fri Nov 13, 2015 8:44 pm
Ok I fixed the last small issues (nothing that would ever have caused an issue in reality, but some internal checks that I built in to detect potential programming errors sometimes failed in a specific mode) during the flight ( :) ).
Build of 7.82 is nearly ready, just have to run the Mac and Raspberry (!) builds.
PostPosted: Fri Nov 13, 2015 9:01 pm
can raspberry work stand alone without PC ? Let say with soundcard that is sell separate and can be fitted with the PI
PostPosted: Sat Nov 14, 2015 12:38 am
Yes but you can only do VERY limited processing.
PostPosted: Sat Nov 14, 2015 5:00 pm
[quote="hvz] Are you entering the URL of the stream itself of a .pls or similar file that contains a list of streams? The latter won't work!
Using a feed from a Barix Instreamer:
URL: http://xx.xx.xx.xx:port/xstream
Works in VLC. cut & paste to ST and it errors out.
Also tried a working configuration without the port number... same result.[/quote][/quote]
Hm... is that the URL of the actual stream, or a stream descriptor? What happens if you open it in a webbrowser?
PostPosted: Sat Nov 14, 2015 5:26 pm
Stream link with VLC works here OK . I`m talking about the input stream via VLC.
But the problem is that the highest RED bar for CPU load is going to nearly full (98%). Is this normal ? I think this is a bug .
Also Hans, correct this "title of the panel" . It not show the ")" after the word "actual" . Just roll the title one position left or it`s a typo
PostPosted: Sat Nov 14, 2015 6:00 pm
It seems that the issue I pointed was not addressed yet.
