Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 345 posts ]  Go to page Previous 13 4 5 6 735 Next
PostPosted: Sat Jun 27, 2015 7:56 am
In the MB2 you can not select the type?
Yes, this is Analog type MB
PostPosted: Sat Jun 27, 2015 5:19 pm
Thanks ;)
by GAP
"Less is More" (Bob Katz)
PostPosted: Sun Jun 28, 2015 5:48 pm
Someone else to see a memory usage increase of about 50-60 MB ?
PostPosted: Sat Jul 04, 2015 3:56 am
Stereo Tool 7.71 BETA004
This version is broken. Please do not download it.
Windows stand alone: -http://www.stereotool.com/download/ster ... 71-004.exe
Winamp DSP: -http://www.stereotool.com/download/dsp_ ... 71-004.exe
Windows VST 32 bit: -http://www.stereotool.com/download/vst_ ... 71-004.dll
There are some big changes in the Composite Clipper in this version. The sound should be the same as before (within 0.02 dB or so). CPU load is much lower though. Please be careful with using this version for anything else than testing until proper functioning has been confirmed.
Note: If you want to use the new composite clipper CPU load optimization with Stokkemask, for now you should set the Stokkemask Quality slider to 3 (I still need to fix that).
TODO 7.71:
- Fix CPU measurement for high loads (jumps to 95% for unknown reason).
- VST multiple instances fails
- Make VST window bigger
- Noise learning Micha
- EQ with 'standard' sliders.
TO DO WITH LEIF:
PostPosted: Sat Jul 04, 2015 8:14 am
Edit : CPU load is OK !!
And why in Advanced clipper , window for the Composite clipper is smaller now only because "oversampled" checkbox is there .
You can make it under the "enable" checkbox and give the old size of composite clipper window.
PostPosted: Sat Jul 04, 2015 8:54 am
Another beta - hooray! Did we miss Beta 03?
With Beta 04 SA, when Stokkemask strictness was set to 3, changing use area from 75% to 100%, I got:
'Exception in: DisplayTwo: Got NAN input for actual. This is not a serious problem but it should not happen.'
Restarting ST with the same settings recreated the exception.
Maybe it's my imagination but the output scope also looked a bit funny at times - it's hard to explain but it's almost like there are split seconds when it shows moments of lower level (from what may be the underlying pilot tone) for longer periods than I expect? Display refresh speed is set at 60% BTW.
Edit: Hmmm. This exception actually seems to be a bit erratic actually. I've also managed to kill the advanced clipper level meters, they seem to have hung.
PostPosted: Sat Jul 04, 2015 9:18 am
Some more oddities in the latest beta:
Switching presets is also doing something strange here - changing from my saved preset to a stock FM preset appeared to kill the FM settings - no pilot / clipper settings present.
Changing from a Web preset back to my saved preset throws the MPX display out too - pilot shifts to the right and cuts off the L-R etc.
Restarting once I got:
'Exception in: ASIO BufferSwitch (Exception 0xc0000005 at address 0xeb6c5a, read/write=1, r/w location=0x18cd19e8). Offset-info: 0xeb7960
Restarting: YES'
PostPosted: Sat Jul 04, 2015 10:28 am
Whoops! Optimization error.... Will rebuild without that optimization for now, and really fix it soon afterwards.
PostPosted: Sat Jul 04, 2015 11:58 am
Stereo Tool 7.71 BETA005
Windows stand alone: http://www.stereotool.com/download/ster ... 71-005.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 71-005.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 71-005.dll
TODO 7.71:
- Fix optimizations
- Fix code #warnings
TO DO WITH LEIF:
PostPosted: Sat Jul 04, 2015 1:48 pm
Finally to test last changes in depth...
- New "highs gap" is noticable worse but uses much less cpu. Makes bigger hole.
- New composite is worse almost not noticable. Worth of CPU.
