Post new topic  Reply to topic  [ 63 posts ]  Go to page Previous 13 4 5 6 7 Next
 Post subject: Re: Stereo Tool 7.50
PostPosted: Sat Aug 02, 2014 8:08 pm
Excuse me PowerSound but what is that mean Pilot=6.8 KHz ?! RDS=3.4 Khz ? Modulation of the pilot and RDS ?
They are also measured same like modulation. "kHz" :)
Pilot 6.8kHz is around 9%
And 3.4kHz is around 4.5%
Yes! And Max dev 75kHz is 100% modulation
The Power of Sound
PostPosted: Sat Aug 02, 2014 9:21 pm
yeah, i got it. 7.5Khz is 10% of modulation , so 6.8 is 9% .
PostPosted: Sat Aug 02, 2014 10:48 pm
Power sound,
like that monitor and case. is it touch screen? can you post a sales link for both of them? thanks
PostPosted: Sat Aug 02, 2014 11:27 pm
Sorry for interrupting but i have a "wish" for version 7.51. Hans i've build a dedicated pc case for ST wich has a 4inch monitor. My wish is to have a way to select the ratio between meters and settings . Thank You very Much.
By the way I've never came across a problem with vlc as an input or output stream...
EDIT: + fullscreen booting
Indeed, that will be nice for my 7inch screen (bad quality picture, because of upload size restriction)
Very nice build. Mine is the worst ever pc case just with 4 inch screen
Some pics while testing
https://imageshack.com/i/iqPs1VQrj
https://imageshack.com/i/kpI7fe9qj
My radio station
http://amradio.ddns.net
PostPosted: Sun Aug 03, 2014 11:59 am
Power sound,
It was with a touchscreen module, but the module broke.. I got a new one, but I couldn't wait to build the case so it's no without touchscreen module.
I'll sent you a pm with sales link. Total price for the case with screen (exluding motherboard, processor etc) is €140/190USD
The Power of Sound
PostPosted: Sun Aug 03, 2014 5:26 pm
Hans ,
now i get the Output buffer (CPU error) and synchro parameters without any restart of the stream . No "stream restarted error" . Why if buffer is full filled M=2.000 and X=1.000 ?
When Buffer becomes unstable - M=1.000 X=1.000
I see also some refresh screen stuttering when this behavour is happened.
When using the Stream via VLC the refresh rate is not like normal operation , i don`t know why.
Will continue to see if i can locate some other causes, that are involved.
PostPosted: Wed Aug 06, 2014 1:15 am
One thing thought.... If i stream in mp3 the qaulity is very bad. But if steam in ogg it is much better.
My settings
--sout=#transcode{vcodec=none,acodec=vorb,ab=128,channels=2,samplerate=48000}:std{access=http,mux=ogg,dst=192.168.1.68:8080/}
--sout=#transcode{vcodec=none,acodec=mp3,ab=128,channels=2,samplerate=48000}:std{access=http,mux=raw,dst=192.168.1.68:8080}
and the money maker... Recording. Firstly MP3. Secondly Ogg
https://drive.google.com/file/d/0BzVv8s ... sp=sharing
IS THIS OK???
My radio station
PostPosted: Wed Aug 06, 2014 4:26 am
I wish you would separate this work. I want all my FM versions to have all this streaming functionality out of it. I wish you would make a streaming version and sell it separately or make it an add on license fee.
PostPosted: Wed Aug 06, 2014 8:54 am
And why if you have it already in the main program , you want is separately ? What is the freaky idea? If you want use it , if you want don`t . It can be maked with ON/OFF switch . Why the hell to be on separate program ?
PostPosted: Wed Aug 06, 2014 12:33 pm
Hi Chris,
Why? If you don't install VLC on the same system it isn't even there...
