Yes, unfortunately it is still happening. Instead of trying to explain clearly, I have instead recorded a video of my screen (no fancy screen recording, just recorded my computer screen with my mobile phone. Don't mind the audio, just my wife watching tv in the background).
Here you can see, that when I crash ST with the TEST ERROR button, and press ok on the following popup, ST crashes and re-opens as it should. However, after 14 seconds, it crashes and re-opens again.
I'm glad that you did, because I probably wouldn't have believed it if you had just told me
. I still don't get it at all - the program does not
know that it has been restarted and that a crash has occurred, so it should behave exactly the same as when it was started the first time. Can you check your C:\temp\Stereo_Tool_Exceptions_log.txt file to see if it contains any extra messages that were not shown in the interface? (That shouldn't be possible either but I really don't know what's happening).
One question: The restarting, does that keep happening, or does it restart twice and then just continue?
This happened when the Normal Output/VLC crash happened. Now, when the Normal Output/VLC crash has been fixed, I can of course not reproduce this error to explain more to you, sorry!
Hey, if it doesn't happen anymore it's ok right?
