Post new topic  Reply to topic  [ 42 posts ]  Go to page Previous 1 2 3 4 5
PostPosted: Sat Oct 09, 2010 4:30 pm
I'm currently testing this preset and i'll give you feedback.
edit: I don't hear that much difference in the quality at 32 kbit/s AAC+ v2 44.1 KHz with parametic stereo.
I've tested it in few types of music (see atached files) and i *think* the preset has much more effect on guitars. So in short this preset is not bad and it does really good job for unprocessed audio, but, when the audio is processed it doesn't improve it significantly.
http://mir.cr/YATBH55B - Generic Balkan music.
http://mir.cr/1PLDACFY - 90's Dance Music
http://mir.cr/K52EVK4B - Today's "RnB" Music.
PostPosted: Fri Nov 19, 2010 6:38 am
Here's my latest preset, built around the latest version of Stereo Tool BETA. I have high frequency response, pretty flat average amplitude, and no "saw-blade" or sibilant S-sounds. :):
[Common]
Pre amplifier=6
Post amplifier=1
Extra loudness=1
Extra loudness - Allow extra highs (advanced)=0
Extra loudness - Punchy=0.284999967
Extra loudness - Max Punch peak=0.75
Extra loudness - Deep bass protection - Enabled=0
Extra loudness - Deep bass protection - Value=0.638750076
Extra loudness - Reflection strength=0.100699991
Bass protection - Enabled=1
Bass protection - Two steps=0
Bass protection - Clip level=140
Bass protection - Deep bass boost=0
Bass protection - Raise clip level if highs get above=150
Bass protection - Maximum clip level raise=35
Hard limit output=1
[Noise Gate]
Enabled=1
Difference=0
Noise level=7.5
Relative noise gate level - Band 3=1.500000238
Relative noise gate level - Band 4=1.702702761
Relative noise gate level - Band 5=1.702702761
Relative noise gate level - Band 6=1.985074759
Relative noise gate level - Band 7=1.857142687
[Singleband Compressor]
Enabled=1
Difference=0
Maximum volume=4
Attack speed=0.000003276
Decay speed=0.00033523
Above Top Limiter=0.810000002
AGC RMS style Enabled=1
AGC RMS style Target RMS level=43550
AGC RMS style Remove remaining peaks above=1
[Pre Compressor]
Enabled=1
Maximum volume - Band 1=27420
Attack speed - Band 1=0.000005458
Attack speed - Band 3=0.000005458
Decay speed - Band 1=0.000028563
Decay speed - Band 3=0.000028563
Dual band=1
Third band=1
Relative expected volume of highs=0.800000012
Relative maximum volume of highs=1.200000048
Relative maximum volume of very highs=0.25
Remove remaining peaks above (relative to maximum volume)=5
Enable smoothing=0
Smoothing time=0
Gating level=2704
Use ITU-BS.1770=0
Channel separation=1
Gating based on volume before Pre Amp=0
Lock bass to band 2 strength=0.349999994
[Multiband Compressor]
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band -1=8000
Maximum volume - Band 0=8650
Maximum volume - Band 1=8650
Maximum volume - Band 2=6250
Maximum volume - Band 3=7450
Maximum volume - Band 4=4950
Maximum volume - Band 5=6100
Maximum volume - Band 6=4450
Maximum volume - Band 7=3100
Maximum volume - Band 8=3400
Attack speeds linked=1
Attack speed - Band -1=0.000031487
Attack speed - Band 0=0.000031487
Attack speed - Band 1=0.000031487
Attack speed - Band 2=0.000031487
Attack speed - Band 3=0.000031487
Attack speed - Band 4=0.000031487
Attack speed - Band 5=0.000031487
Attack speed - Band 6=0.000031487
Attack speed - Band 7=0.000031487
Attack speed - Band 8=0.000031487
Decay speeds linked=1
Decay speed - Band -1=0.000251468
Decay speed - Band 0=0.000251468
Decay speed - Band 1=0.000251468
Decay speed - Band 2=0.000251468
Decay speed - Band 3=0.000251468
Decay speed - Band 4=0.000251468
Decay speed - Band 5=0.000251468
Decay speed - Band 6=0.000251468
Decay speed - Band 7=0.000251468
Decay speed - Band 8=0.000251468
Above Top Limiter=0.550000012
Clipping enabled=1
Postprocessing enabled=1
Flat frequency response enabled=1
Relative clip position - Band -1=-1
Relative clip position - Band 0=-1
Relative clip position - Band 1=-1
Relative clip position - Band 2=-1
Relative clip position - Band 3=-1
Relative clip position - Band 4=0.801801801
Relative clip position - Band 5=0.709401608
Relative clip position - Band 6=0.65289247
Relative clip position - Band 7=0.503759503
Relative clip position - Band 8=0.503759503
Final limiter value=1
Final limiter decay speed=0.999000013
Final limiter clipping=20
Equalizer enabled=0
Equalizer position - Band -1=1
Equalizer position - Band 0=1
Equalizer position - Band 1=1
Equalizer position - Band 2=1
Equalizer position - Band 3=1
Equalizer position - Band 4=1
Equalizer position - Band 5=1
Equalizer position - Band 6=1
Equalizer position - Band 7=1
Equalizer position - Band 8=1
[Stereo]
Enabled=3
Stereo AZIMUTH Enabled=1
Stereo Image Enabled=0
Stereo Boost Enabled=1
Stereo Boost Excessive Reverb Protection Enabled=1
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=30.000001907
AZIMUTH change speed=0.25
Image phase amplifier=1.25
Image phase amplifier maximum angle=150.300003052
Image phase amplifier maximum separation strength=75
Image width amplifier=0.699999988
Extra phase shift=0
Mono or stereo only=-0.100000024
Stereo Boost strength=5
Stereo Boost maximum amplification=2.5
Stereo Boost multiplier=0.600000024
Stereo Boost - Never reduce below original level=0
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=1
Lowpass filter=17500
Highpass filter=25
[Bass Boost]
Enabled=0
Strength=1
End lowpass frequency of input filter=250
Start lowpass frequency of output filter=250
End lowpass frequency of output filter=350
Clip level=1.5
Preserve louder peaks=1
Difference=0
[Phase Rotator]
Enabled=1
Start frequency=3500
Start speed=3500
Number of rotations=5
Smoothness=0.980999947
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1.5
Pre-limiter enabled=1
Pre-limiter relative volume=1
Reduced CPU processing=0
[FM Transmitter]
Enabled=0
Pre-emphasize=0
Pre-emphasis time=50
Output is pre-emphasized=0
Stereo encoder enabled=0
RDS encoder enabled=0
Pilot signal volume=9
RDS signal volume=4.5
FM overdrive volume=1
RDS PS text=2s:STEREO/2s:TOOL/<1=1.5s,2..-2=2t,-1=1.5s:WWW.STEREOTOOL.COM/|\W"PLAYING %artist% - %title%        "/1s:\T2h\:\T02m\:\T02s/1s:\T2h\:\T02m\.\T02s/1s:\T2h\:\T02m\:\T02s
RDS RadioText text=60s:Stereo Tool: Professional Audio Processing - www.stereotool.com/30s:Stereo Tool by Hans van Zutphen, 1999-2008 - www.stereotool.com/30s:\W"%artist% - %title% - %album%"
RDS PTY=0
RDS PI=65535
RDS Alternative frequency 1=0
RDS Alternative frequency 2=0
RDS Alternative frequency 3=0
RDS Alternative frequency 4=0
RDS Alternative frequency 5=0
RDS Alternative frequency 6=0
RDS Alternative frequency 7=0
RDS Alternative frequency 8=0
RDS Alternative frequency 9=0
RDS TP=0
RDS TA=1
RDS Music=1
RDS Artificial Head=0
RDS Compressed=1
RDS Dynamic PTY=0
RDS RadioText Enabled=1
RDS ClockTime Enabled=1
[Lossy compression output optimization]
Enabled=1
Spike Protation pre-emphasis time=30
[Direct soundcard access]
Enabled=0
Volume=1
Buffer size=1
Send to Winamp=Nothing
ASIO Override channel 1=4
ASIO Override channel 2=5
[Low latency output]
Enabled=0
Volume=1
Buffer size=0.080000006
ASIO Override channel 1=2
ASIO Override channel 2=3
10AG1.zip [2.45 KiB]
Downloaded 621 times
