Post new topic  Reply to topic  [ 299 posts ]  Go to page Previous 13 4 5 6 730 Next
PostPosted: Sat Apr 06, 2013 2:35 pm
Looks like new mpx clipper :)
Yes. And it really helps with the highs, and I see that left and right modulation has peaks to over 150%! (Actually, the version from 2 days ago had peaks upto 169%; I know how to get that back and I'll restore it soon).
PostPosted: Sat Apr 06, 2013 2:42 pm
In case anyone wants to test:
Stand alone: http://www.stereotool.com/download/ster ... 20-003.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 20-003.exe
VST: http://www.stereotool.com/download/vst_ ... 11-020.dll
IMPORTANT: To get a good sound from the composite clipper:
1. Enable it :) It's an option under Advanced Clipper
2. Under Advanced Clipper -> CPU, set 'Strictness' to 20 (at least above 10; check how much your CPU can handle) and Stronger Clipping to around 25-30%.
This thing uses a LOT more CPU power, and it's currently not using any multi-threading. My i7 laptop can barely run it, and I need to set the Strictness value to 12.
If you use the composite clipper, the output level will be higher, and especially the highs will be brighter. Also, there's more headroom to increase the Loudness even more.
Warnings:
1. This version contains a bug. I don't know what it is, but when I close it it crashes. This could lead to any type of weird behavior on other systems, so don't use it on-air yet!
2. You will need a license update to use this! Otherwise the 'unregistered options in use' thingy will pop up, and you'll get messages through the music (every 4 hours).
PostPosted: Sat Apr 06, 2013 2:48 pm
Warnings:
OK, en how can i update my licence ?
PostPosted: Sat Apr 06, 2013 3:02 pm
It's not crashing here when i close it. Tried standalone and winamp DSP. No problems here.
PostPosted: Sat Apr 06, 2013 3:49 pm
Are we having fun yet? Rockin the genelecs!!!
PostPosted: Sat Apr 06, 2013 3:51 pm
I can't get the same effect as in sample file...
I found :)
Urban Junglist
PostPosted: Sat Apr 06, 2013 4:20 pm
http://radiodiscussions.com/smf/index.p ... =232329.30
PostPosted: Sat Apr 06, 2013 4:59 pm
Great!!!!!!
No crashing at all!!
License Update?
Os: server 2008 32bit
Groet
PostPosted: Sat Apr 06, 2013 5:20 pm
Composite Clipper doent get Blue when enable, is this bug too, or i am doing something wrong?
Sexy Girls in your city
PostPosted: Sat Apr 06, 2013 5:24 pm
Since it's for FM, you can try to turn ON FM first.
