Post new topic  Reply to topic  [ 103 posts ]  Go to page Previous 13 4 5 6 711 Next
 Post subject: Re: Stereo Tool 7.00
PostPosted: Fri Dec 14, 2012 9:33 pm
@hvz: In the download section of the ST site says "LATEST VERSION AVAILABLE: 6.32" instead of 7.00. :)
Caching issue - it's an iframe and for some reason it doesn't easily get reloaded (depening on the browser).
Ok, I forced clearing the cache of Firefox and now appear correctly. ;)
by GAP
"Less is More" (Bob Katz)
PostPosted: Fri Dec 14, 2012 9:40 pm
because instead of the 12 hours, the jingle turns in every half hour/hour :mrgreen:
Not that I know of........... :shock: Just looked at the code and it says the same as before: Every 12 hours for either FM or Loudness, and if you use both every 4 hours.
Can you send me your settings?
shure can ;)
PostPosted: Fri Dec 14, 2012 10:22 pm
Open up Reaper and on the left hand side double click on the blank track control panel,This will create a track then click on the fx button.Reaper will scan the program for plugins.Stereo tool will most probably not be there so you have to create a path for Reaper to access the plugin so go to Reaper "Options"(top of the screen) scroll down to "preferences"click on preferences and a box will open with all the prefernecs.
Thanks, that helped! What's happening is that I have a thread that handles (re)draw requests (it basically bundles them to avoid overloading the CPU), this thread shoots off events to do the actual drawing and then waits for a reply event. For some reason however, the first draw event never arrives in the window message loop. So the bundling thread just keeps waiting.
This request thread was added when Brian complained about a much higher CPU load, could very well be in version 054. Now I just need to figure out *why* the event doesn't arrive... That, or override it if there's no 'yes I've drawn it' event coming back for a while, if I can't find a better fix.
PostPosted: Fri Dec 14, 2012 10:30 pm
Hans I have a problem.In the vst version of stereo tool 7 there is no GUI.I´m using this in Reaper.When I open the plugin it comes up blank. :x
Still don't know what's going on here. I looked through the changes between the used beta (063) and the current release and there's nothing there that should be able to cause this. Currently waiting if I get more reports like this. VST version works fine here - unfortunately...
It happens for me also (I use Plogue Bidule) but NOT when I first start-up a layout, then the GUI works fine, it's only after I made some adjustments in ST, close it and then re-open the ST GUI, then it's completely blank and stays that way until I close and reopen Plogue.
PostPosted: Fri Dec 14, 2012 10:34 pm
Ok, I had 2 ways of displaying: The Winamp/VST method and the stand alone method.
Now changed the VST method to do the same as stand alone and it works! Not saying there may not be any updating issues with the GUI but so far it looks good.
PostPosted: Fri Dec 14, 2012 11:23 pm
Reduce the number of additional calculations in the various filters... 8-)
You know I had to say it... :mrgreen:
PostPosted: Sat Dec 15, 2012 12:55 am
@Bojcha: You mentioned loud sounds going into the clipper when you enabled certain presets. I checked what happened and it turns out the be the singleband compressor. When you press RESET the current level is set to '1' - I've removed that now and the effect is gone (but if you load a different preset which has very different levels in the singleband compressor it might take some more time for the level to get up if it was below 1).
But it's probably better to have a softer sound than a louder one.
Because I'm not 100% sure that the VST fix will work on all systems I'll post a beta first, if I don't get any complaints about it I'll release version 7.01 in the next days.
PostPosted: Sat Dec 15, 2012 1:04 am
TODO: Add sound card restart button again (Bojcha just reported that it's missing)
TODO: Fix sound card reset on built-in preset load
PostPosted: Sat Dec 15, 2012 8:19 am
@Brian :
And why Hans to reduce calculations for something ?
To reduce the quality ?
Or you don`t have 200$ to buy a double core CPU with mainboard? How do you think to use ST with almost 100% machine load ? You can`t . Machine must Breathing !!!
PostPosted: Sat Dec 15, 2012 10:39 am
Stand alone: http://www.stereotool.com/download/ster ... 01-001.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 01-001.exe
VST: http://www.stereotool.com/download/vst_ ... 01-001.dll
Command line: http://www.stereotool.com/download/ster ... 01-001.exe
DONE:
- VST version should work properly now
- Some presets updated
- Volume increase when loading a preset fixed
- GUI unresponsive at very high CPU loads when you click right of text in text box fix
Still need to look at:
- "This sound is processed by" plays too often
- Add sound card restart button again (Bojcha just reported that it's missing)
- Fix sound card reset on built-in preset load & FM settings - now making as little changes as possible, hope this is better
Other stuff that I've been pushing forward (and will push forward further for now):
- Add 'purpose based' view on settings (for example all settings that affect bass combined).
- Multi-language support
- Add basic/advanced modes
- Confirm on close (stand alone version)
