Post new topic  Reply to topic  [ 752 posts ]  Go to page Previous 13 4 5 6 776 Next
PostPosted: Tue Aug 21, 2012 2:09 pm
@DJ_DOGGY: Still need to do that.
- Optimization: Requests are bundled before they are sent to the server
- Right click repeats on hold
- Validation added (multiband freqs cannot be higher than next or lower than previous; similar issue for bass boost). (Did I miss any?)
- Some sliders (multiband freqs) right click now increases/decreases by 1 Hz always (before it didn't because it uses logarithmic scale).
- Also did something with dragging the slider on mobile browsers. But it doesn't work well (site itself is still moving, and the changing values are not refreshed at least not in my browser, but they *are* sent to Stereo Tool...)
http://www.stereotool.com/download/ster ... 33-006.exe
In the mean time, the slider display is redesigned by Bojcha. I think the whole interface looks way too dithered and noisy, but I'm now focussing on getting things to work rather than to look good...
PostPosted: Wed Aug 22, 2012 1:25 am
Optimized HTML (moved things from HTML to CSS, which will facilitate skinning later).
"Rocket" like sliders are now displayed the same as other sliders (so only 1 type of sliders left).
http://www.stereotool.com/download/ster ... 33-007.exe
http://www.stereotool.com/download/dsp_ ... 33-007.exe
PostPosted: Thu Aug 23, 2012 4:09 am
http://i.imgur.com/SVkfI.png >?
PostPosted: Thu Aug 23, 2012 2:46 pm
Looks good!
I expect to have a skinnable version ready this afternoon!
PostPosted: Thu Aug 23, 2012 4:22 pm
First (partially *) skinnable version!
http://www.stereotool.com/download/ster ... 33-008.exe
You can now also change the port number (note: If you turn the server OFF or change the port number to something unreachable, the only way to fix that is by manually editing the .ini file or removing it!). Port number is displayed in HEX!!! (It's 8000 by default).
To make a skin
- Upload the needed images to a web server
- Fill in the directory where they are available in the Skin box (general settings)
- Reload the page
Example skin (incomplete, this was the version from yesterday): http://www.stereotool.com/webinterface/bojcha/
(Note the trailing / !)
If you want to change the font or even the way objects are generated, you can place a skin.css and skin.js file in the same directory with settings and functions that override the defaults.
* Partially because there's still no control for the size of each blok (the total line always fills the screen upto 100%)
PostPosted: Thu Aug 23, 2012 5:22 pm
If you redownload version 008 now the port number is displayed in decimal instead of hexadecimal notation, and it works now (before the setting was ignored). Note: You need to restart Stereo Tool for the port and webserver enabled settings to be activated.
PostPosted: Thu Aug 23, 2012 8:16 pm
Skin update v2 - http://85.25.73.243/stereotool_skin_b2/
PostPosted: Fri Aug 24, 2012 2:19 am
Bojcha: congratulations on the design! :D , I'm currently using. however I could not test the version 2, because I have no permissions on your server.
Hans: Because the interface is loaded from internet?, This slows much load.
PostPosted: Fri Aug 24, 2012 3:07 am
Nelson..
You need to..
- use last beta008
- Put that line in here http://i.imgur.com/tZN0B.png (that is in "Global Settings")
- Press "enter" while you on that line
- Restart Stereo Tool and refresh page
I also updated skin, so everything what i will i edit in skin, you'll see.
PostPosted: Fri Aug 24, 2012 3:11 am
Skin is on my server which is very fast, so loading should be instant ;)
