Post new topic  Reply to topic  [ 69 posts ]  Go to page Previous 13 4 5 6 7 Next
PostPosted: Sun Jul 29, 2012 2:39 am
Updating the preset for the ST version 6.32 beta 17. ;)
GAP_BlueSky_v0.92.zip [4.38 KiB]
Downloaded 585 times
by GAP
"Less is More" (Bob Katz)
PostPosted: Mon Jul 30, 2012 5:28 am
Fine tuning in the bass. ;)
GAP_BlueSky_v0.93.zip [4.27 KiB]
Downloaded 488 times
by GAP
PostPosted: Thu Aug 02, 2012 4:46 am
Fixed the value the sensitivity in ABDP for ST v6.32 beta 20.
I think it's the last modification to the final version. :)
GAP_BlueSky_v0.94.zip [4.28 KiB]
Downloaded 595 times
by GAP
PostPosted: Thu Aug 02, 2012 6:08 pm
hello there,
my webradio is back on air now with your preset, so i will give you the link as i told you ;).
you can listen here: http://174.37.194.139:8104/listen.pls
with kind regards,
wouter
PostPosted: Thu Aug 02, 2012 6:31 pm
hello there,
with kind regards,
wouter
Thanks Wouter, I will listen your web radio, when I get home. ;)
by GAP
PostPosted: Thu Aug 02, 2012 11:09 pm
hello there,
with kind regards,
wouter
i feel sorry to say, but i stopped the broadcast, because i got a hard and long day tomorrow. and my microphone got sick in the last hour.
maybe you can listen sunday? then i will put in 24 hours on air, so you can listen to ;)
with kind regards,
wouter
PostPosted: Fri Aug 03, 2012 5:32 am
no problem, hear from Sunday. ;)
thanks
by GAP
PostPosted: Sat Aug 04, 2012 8:16 pm
okay,
its on air from now until tomorrow 12:00PM
so let me know what you think ;)
EDIT:
while i got some private issiues i stopped my broadcast earlier, today.
maybe i will come back on air, tonight but i don't realy think so.
with kind regards,
wouter
PostPosted: Sun Aug 05, 2012 4:37 pm
okay,
EDIT:
with kind regards,
wouter
I could listen to your stream yesterday, and really sounds good! :mrgreen:
Clean, with presence and deep bass.
If there is something to review, but very minor, is some highs that are a little harsh (could be any preemphasis in the encoder, coupled preenfsis ST)
Greetings and thank you very much for letting us listen. ;)
by GAP
PostPosted: Thu Sep 06, 2012 4:50 am
Here is a new version of the preset.
The changes made are in the bass sound.
More dynamic, deep and very stuck, I hope you like this new sound! ;)
GAP_BlueSky_v0.95.zip [4.27 KiB]
Downloaded 1260 times
by GAP
