I always analyse the output in Cool Edit (= Adobe Audition) and it always shows a VERY steep drop to below -90 dB within a few hundred Hz.
So please try what Eldoradofm suggested. Also check that your 'post amp' is not set higher than 1.00 and that Hard Limit is enabled. (If you have overshoots you'll get this type of behavior).
How would you propose recording? Is the Nullsoft writer good enough, or do I need to break out some other program that I may or may not have?
Further, I do not have Cool Edit, and my understanding is the trial of AA is crippled.
Post amp is set for x0.95 and Hard Limit is enabled, and the preset is publicly available. I can work around it using band changes and clipping...
Edit: Tinkering with it, volume increases in the Wave slider impact RTA, while volume increases through the Master Volume do not. This means it could be an RTA issue
OR an issue with StereoTool that you would not notice if you use Master Volume and hold the Wave level back.
My question is if it is thought that the bandpass is steep enough. If it is felt that it is, then I'll continue with plans on addressing through band changes and clipping.
