Post new topic  Reply to topic  [ 171 posts ]  Go to page Previous 13 4 5 6 718 Next
 Post subject: Re: Stereo Tool 6.20
PostPosted: Mon Nov 07, 2011 1:31 pm
Version 6.20 is super wowowoowwo!
( i use standalone version for fm broadcasting and i am very happy! )
BUT BUT BUT... Hans , can you add on your todo list a "dsp host " for your standalone version of stereotool ?
I would be gradefull if you could make this simple code becuse i need some dsp plugins on ..standalone version of stereotool
thank you for everything!
PostPosted: Mon Nov 07, 2011 8:40 pm
Issue fixed! I uninstalled all of my winamp and removed everything it leaves behind in hidden folders and what not. Then I re-installed it all again, and its gone 48 hours with no crash. I think we are good to go now. Sorry for wasting your time if I did. I'm still not sure what caused it as all I changed was to 6.20, and when I'd go back to older versions it was fine, but now it seems fine with 6.20 and I'm happy.
Thanks again for an awesome product!
-n4-
Also wanted to add that I updated edcast http://code.google.com/p/edcast-reborn/
It had been a bit since I had updated Edcast because they hadn't updated it in about a year so I didn't check that one a lot. I did this when I re-installed everything. Not sure if that was the fix, but it was a nice update. Some cool features in the new version. Thanks again.
PostPosted: Sat Nov 12, 2011 10:37 pm
Sublime! :P
PostPosted: Sun Nov 13, 2011 11:05 am
Think I found a small bug. 'FM RDS TA' on the main GUI cannot be activated even if TP is activated.
PostPosted: Sun Nov 13, 2011 8:09 pm
I found a bug in the VST Version:
If you have selected in the loudness maximizer x 4 ( 12 db) and then close the window and reopen it again the value is always x 3 (9 db). All other settings are at the same value before closing the window.
This only occurs if you set the value > x 3 of the loudness maximizer
PostPosted: Sun Nov 13, 2011 11:32 pm
I found a bug ....
Welcome! :D
It is better to post bugs there
:arrow:
viewforum.php?f=15
PostPosted: Tue Nov 15, 2011 2:28 am
Im already missing the new betas.... can't live without them LOL, i love your work!!!
PostPosted: Tue Nov 15, 2011 2:43 am
Will start working on things in a few weeks again - currently just finishing up my 'old' (current) job and preparing some other stuff (office, website, taxes, ...). They will come again!
PostPosted: Tue Nov 15, 2011 6:13 am
Im already missing the new betas.... can't live without them...
PostPosted: Mon Nov 28, 2011 2:28 pm
Is there a solution to prevent straying of vocals in AGC for large channel separation values other than not using such values?
visit website
