Post new topic  Reply to topic  [ 48 posts ]  Go to page Previous 1 2 3 4 5
 Post subject: Re: Stereo Tool 9.40
PostPosted: Wed Apr 22, 2020 7:02 pm
i had this issue awhile back and discovered the fix (for me) was to set the sound devices in windows that are being used, in the "recording tab" under "listen to this device" to a sound card that is not being used.
the example photo attachment shows the line input which is being used, ticked to "listen to this device" to the SPDIF output which isnt being used.
Thank you! I'll definitely try this trick next time I encounter this issue.
PostPosted: Thu Apr 23, 2020 2:33 am
For the next beta please fix:
1) The resample issue in "Streaming Output": when try to stream with icecast with ogg codec and FM trasmitter at the same time, sample rate at 192 kHz... the streaming is at 192 kHz too, it should be at the sample rate setting in the "streaming output" (resample).
2) When FM Transmitter (FM output) is used with "normal output" and/or "streaming output" at the same time the "extra composite clipper drive" level have effect over normal output and or streaming output, and only have to affect to FM Output. For example: if I up the extra composite clipper drive to 2 dB (max level) the level in normal output and streaming output its up too the same loudness.
3) In Noise Gate section all the bands are showing 0Hz
Request: Please add a stream URL (via VLC) option in Input #2 for backup use.
Stereotool is fantastic and awesome. Keep the good work.
Thanks to Hans and the team.
1) Do you mean that you've set the sample rate to 192? Then this makes perfect sense... If you want to run FM at 192 and the stream at 48, then select 48 as the sample rate; FM will automatically pick a higher sample rate. Note: This does not work with ASIO.
2) O. I need to figure out how to solve that, because just fixing it will affect the levels of stations that are using it.
3) Fixed
Request: Not that simple, but we are working on a new audio framework in which this should be much simpler.
Thank you very much Hans...
https://fmfeeling.com
PostPosted: Thu Apr 23, 2020 4:12 pm
perhaps i'll make a informational thread on optimal windows 10 settings and certain settings for ST to operate flawlessly.
at this point, im using ST 9.40 x64 on windows 10 pro x64 v2004 b19041.207 with 25mS latency as a processor for incoming audio from the web and for processing incoming audio from a cable box using a DD5.1 decoder as its important to have minimal latency for this content.
PostPosted: Thu Apr 23, 2020 6:12 pm
I enabled Legacy Relative Release release in multiband 1 & 2 and singleband, I saved the preset when the preset was reopened LEGACY RRD was disabled, tried in 9.40 and 9.37, same problem.
PostPosted: Thu Apr 23, 2020 6:14 pm
it would be a good thing. ;)
PostPosted: Sat Apr 25, 2020 3:24 pm
Could it be a CPU usage issue anyway? The fact that it mainly happened when Rivendell switched to a new song would point at that (since Stereo Tool doesn't know anything about that). What was the CPU load/"time spent in processing" that Stereo Tool reports under "CPU & Latency"? Dynamic speeds use more CPU.
I traced it back to buffer over and underruns in Jack (Xrun errors). After some reading I changed the framerate from 4096 to the highly unusual setting of 4110. The broken audio is no longer an issue but is for 99% sure caused by the Jack version of Stereotool. When we had license off the message didn't say "this sound is processed by ST" but "s-s-s-s-s-s-sound is processed by ST", and this was so far the only broken audio with framerate 4410. The 4110 framerate is related to 44.1 khz wav's, because digital audio always seems to need 48 in Jack connections. Note: the system is running at 12-16% CPU and lots of free memory (8 gig reserved for this VM)
Could you please also have a look at Stereotool Jack version ALWAYS connecting to system at startup. Stereotool is incorrectly overriding the defined patchbay. System most of the time are sound cards. But in a digital setup the patchbay (we use jack_load netmanager with manual setup in .jackdrc) in Jack has no soundcard. System is just the output to the other nodes on the lan and should not be connected to at start up.
https://maasstad.online/
PostPosted: Sat Apr 25, 2020 4:25 pm
Doesn't reproduce here, which exact version are you using (DSP/VST/stand alone, Windows/Linux/Mac/Pi, 32/64 bit)?
PostPosted: Mon Apr 27, 2020 8:31 am
Standalone 9.40, x64, win 10pro ,ver. 1909, build 18363.778
I tried again and does not save on the preset, also tried on my laptop always stand alone 9.40, x64.
tell me if you need something that can help you understand.
