Post new topic  Reply to topic  [ 78 posts ]  Go to page Previous 13 4 5 6 7 8 Next
PostPosted: Fri Feb 08, 2019 7:56 pm
DSP beta 9 and 10 are bit identical, again. :roll:
PostPosted: Fri Feb 08, 2019 8:15 pm
DSP = 009 . standalone = 010 I think hans made a mistake :(
PostPosted: Fri Feb 08, 2019 8:17 pm
Parts of the build have failed, apparently the DSP was one of those. I'll just start another beta build now.
PostPosted: Sun Feb 10, 2019 9:12 pm
BETA013 is avaialble! The most important change (which was already partially there in 012) is that if you use an RMS size in the analog compressors, protection against overshooting is added to the behavior. So, for example, a really loud S in the highest band is at roughly the same level, but before, the level would keep dropping for a short while. That's now fixed - and because of that the audio after the S is 2-3 dB louder than before! So, this sounds much tighter, and better controlled. Far less gaps in the spectrum after some loud sound.
This new setting is now available in all the analog compressors, and in the AGC.
PostPosted: Mon Feb 11, 2019 11:26 am
Hans,
I've found a bug in Beta013, in the equalizer section, there's 2 before multi-bands & 1 between multi-bands.
The first before multi-bands is actually before, the second before multi-bands is actually between, & the between multi-bands, the entire equalizer section disappears off the left hand side list.
PostPosted: Mon Feb 11, 2019 4:28 pm
Hanz,
Beta12
Changes/bugfixes: Fixed use sound card #2 as backup behavior after startup.
It's the problem that I had signaled when backup sound was somethime at startup mixed with main sound ?
Thanks
Stef
Hanz,
Beta12
Thanks
Stef
Yes!
PostPosted: Mon Feb 11, 2019 7:41 pm
I'll ask you one stupid question. Could you transfer the new window settings to the MBs and compressors? Here you can also set a window, and this could also be useful here, or am I completely mistaken? :roll:
PostPosted: Tue Feb 12, 2019 4:04 am
There's no button to turn off licensed features in the web interface?
One other thing I've noticed is with Basstardizer gone, the level slider on the web interface for it on the Processing page is gone. However the button to toggle Basstardizer on and off is still there, and I personally liked Basstardizer more than TrueBass, because with Basstardizer you can set the frequencies (at least in basic mode).
Should the button to turn Basstardizer off be removed?
PostPosted: Tue Feb 12, 2019 5:41 am
One more suggestion, for those few of us who use the web interface can you add more sliders, (AGC and multibands mainly) on the Processing page?
