Post new topic  Reply to topic  [ 54 posts ]  Go to page Previous 1 2 3 4 5 6 Next
PostPosted: Fri Dec 02, 2016 10:57 am
Ah! 8.14 is already released (and that bug is fixed).
PostPosted: Fri Dec 02, 2016 10:18 pm
PostPosted: Mon Dec 05, 2016 2:41 pm
sounding great.I like very much Hans preset Analog Pleasure.thanks.
PostPosted: Tue Dec 06, 2016 8:06 pm
In the latest Windows VST version I have the following problem. It always cuts the beginning of an audio file. It always starts hard and directly. I do not know how much is cut off, but it should be a few milliseconds. This was not the case at all.
PostPosted: Wed Dec 07, 2016 3:23 am
possible bug in 8.14 ?
In absolute highs, if the checkbox to link it with delossifier is On, it does not seem to work. Whether delossifier detects MPEG or not, no audio output can be heard. However setting this checkbox off, there is generated audio.
PostPosted: Wed Dec 07, 2016 3:38 am
I don't see this in the Winamp/DSP version.
PostPosted: Thu Dec 08, 2016 1:12 am
Allow me to give more details, that may help:
- source a low bitrate mp3
- VST version of Stereotool 8.14
- do a full reset on all settings
- in processing set pre amplifier to get a normal audio volume, depends on your input
- in absolute highs set the max generation frequency to 2500 (exagerated of course) and slope up to 5000. listen to the difference, you will hear it very clearly.
- now, turn on delossifier, all default settings, both pre ringing and spectral options. Immediately the effect of absolute highs is killed IF the "follow delossifier" option is on. Almost like that option is doing just the opposite??
hope this helps to reproduce and correct, thanks guys
PostPosted: Thu Dec 08, 2016 10:33 am
Ow. Follow Delossifier means that the frequency above which it operates is the highest frequency in the audio that the Delossifier detects. So you should definitely hear less!
PostPosted: Thu Dec 08, 2016 6:23 pm
Thank you very much for the information! For some reason I believed that "if Delossifier detects MPEG then follow its suggestion to generate highs, if not MPEG, then don't" :)
best regards
PostPosted: Sun Dec 11, 2016 4:45 pm
This is a problem with the current (8.14) DSP version:
Will try 8.14 Beta 2.
C.
Edit: Works fine in 8.14 Beta 2. No error.
