Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 138 39 40 41 4259 Next
PostPosted: Sun May 01, 2016 11:22 pm
I'm using v7.85 BETA056 right now, and it's warning me about the FM soundcard sample rate being too low for RDS only when I have the "Sound cards" --> "FM Output" turned off. I'll try with your next build to see if it changes.
PostPosted: Mon May 02, 2016 4:11 am
De-Esser don't work with 192khz in FM Mode from 7.85 BETA062
PostPosted: Tue May 03, 2016 7:20 am
Anybody else been trying out the 'Multipath Stereo Phase Difference Remover'?
It sometimes seems difficult to (subjectively) know how much something is helping? I'd like to hear about other's experiences!
I'm not sure if it really does anything. It might. I have set the default values to 3500 / 6000, that seems to be the lowest that doesn't noticably reduce stereo separation when I listen on speakers. However, other people might hear things differently...
Interesting. I am now trying much higher frequencies (8125 / 13 000 Hz).
When I used the initial settings (defaults which were much lower?), I though I heard a change in the high end which sounded more 'boring' / had less width - but who knows how much of that is real?!
Does someone have the ability to lab test this?
PostPosted: Tue May 03, 2016 2:50 pm
Certainly doesn't helps to reduce multipath.
Tested with low signal.
PostPosted: Tue May 03, 2016 3:38 pm
From my experience with multipath areas on FM :
1 ) Play with a LOUD preset ( and ..as clean as possible )
( you MUST ALSO control within normal limits your stereo enhancing settings for not making big difference when switching to mono from stereo in low signal areas )
2 ) Use normal stereo pilot and rds levels
3) IF you have a LOUD ( high dbr ) preset , YOU MUST PLAY AT 63 to 66 KHz MAX DEVIATION ,
NOOOOOOOOOOT 75 khz !
AND ...if you have the money , use SFN broadcast ( DDS EXCITERS , like ... http://www.sigmacom.gr )
PostPosted: Tue May 03, 2016 6:24 pm
Multipath is not about low signal.
PostPosted: Wed May 04, 2016 6:55 am
7.85 BETA065
Windows stand alone: http://www.stereotool.com/download/ster ... 85-065.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-065.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-065.dll
CHANGED:
- OPTIMIZE DELOSSIFIER
- Reduced stack usage, hopefully fixes crash issue
- Fix AGC ratio display
- Absolute Highs: Optimize performance: Check log() -> Removed most (256 to 40 per step), and part of code that's not needed disabled for Delossifier.
- Exciter: Try to reduce pre-ringing (maybe by doubling overlap? Or measure on bigger block size, then go back to smaller?) Is this still a problem? -> Doesn't seem to be.
- Fixed GUI bug. Maybe that fixes the gray screen that was reported by RadioImInternet - but I'm not too sure about that.
- Bug: Stereo Image Phase to 0 reduces L-R anti-phase sounds by about 6 dB, and also not constant. (This is new, used to be good before!) Problem occurs when feeding 100% anti-phase, even 1 degree difference between channels fixes it completely. -> Effect is reduced now, hopefully acceptable.
- Add Ratio to AGC
- Add Analyzer BYPASS mode (is that needed??) -> No, probably works already, but despite that, we can use a separate PC at the NAB for this.
- All L/R - L/R Quadrature mode, test with noise -> Doesn't work :(
- Add FM phase shift remover for high frequencies for Multipath
- Input Gain issue (see 2 posts below BETA054)
- LW SKIN!
- uM: Filter and add vac1/2/3/... option!
- Fixed broken VST plugin.
- Delossifier: Added MP3 detection filter; turn it on to disable the Delossifier when it thinks that the input is not an MP3.
- Delossifier: Protection added to not add too much. The result sounds cleaner, but it might also be slightly less effective. In total I think it's better.
- Detection and reconstruction both fail in 60's song Lay Down! -> Better now, but: 1. Make sure that this doesn't reduce repair elsewhere (some other parts are better now too, so be careful with that!). Maybe only remove narrow 'gaps' in the xmul array. 2. Improve detection to make Lay Down sound good always. It's not even an MP3! Check not only close to border but also a bit higher - should be nearly perfect silence! Maybe also some slowness in starting to repair?
- Absolute Highs: CRASH!
- Add Quadrature monitoring
- SPA remove monthly popup
- Added other optimizations
- Fix crash in BETA036.
- Exciter: Add Volume slider
- Exciter: Add DIFF mode
- Fixed crash when closing
- GUI: Added tooltips!
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- Bass AGC (Old) is broken!
- Check Sort algorithm optimization
- Clipper on separate CPU for ARM - or move around on cores?
- Normal Output: Don't output FM anymore!
- Absolute Highs: Check how slowly the frequency should rise. Probably should only be available if Delossifier freq responds slowly? (Maybe already ok?)
- Crashes sometimes (since 061).
- Add separate watchdog process - see Zuidwest FM email dd 2016-04-20 12:24
- Delossifier: Lay Down breaks Delossifier, sounds really bad with MP3 detection turned off! (And it's not MP3). More accurate detection (smooth rolloff??) still needed, to also not detect it when not using Detect MPEG mode! Does Alternative Method sound better now?? Also try without HACK.
- OS X update wxWidgets for 10.10.5 compatibility.
- Make DIFFERENCE work in Natural Dynamics for separate bands
- Add RDS HTTP commands (Nashville)
- Add HTTP commands and feedback - viewtopic.php?f=16&t=7701&p=34436#p34436
- Add sound card adjustment presets for analog sound cards.
- Input Balance issue (see 2 posts below BETA054), cause known (reallocalte big buffer for waveform display, then buffer size doesn't match, and for some reason this causes a shift in time. However, calculated values appear to be correct. Check in more detail after NAB.)
- License check
- set Encryption : impossible to view or modify all the processing settings
- Preset Licensing : encrypted preset without beeps unlocked by a license
LATER:
- Add auto detection of certain sound cards, like Marian Trace Alpha.
- O skin
PostPosted: Wed May 04, 2016 7:17 am
What's that about?
PostPosted: Wed May 04, 2016 3:17 pm
Not crashing anymore but still sounding terrible, like your in another room listening to the neighbors play their stereo too loud and the walls are rattling. :lol:
After playing around and troubleshooting because earlier standalone versions sound great, I did a reset and started turning things on to see what was causing it. It sounded good on everything I tried. Was a dead end for me...
So I selected the SoundPro Omni FM 75 preset (Which I like best) then it sounded terrible again, argh. So I started turning things off from there, which I did find a problem. :o It's in the Processing>AGC>Compressor. I turned it off and a new selection came up (Weird). Basic AGC (Old), I turned that off also and the sound cleared up. Then the menu showed 2 Compressors until I selected the newer Compressor and turned it on. Sounds really good now. Clearer highs.
PostPosted: Wed May 04, 2016 6:27 pm
Confirmed - Bass AGC (Old) is clearly broken. Added to todo list.
