Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 137 38 39 40 4159 Next
PostPosted: Thu Apr 28, 2016 3:13 pm
DSP does not work. StereoTool-Window opens but stays gray, without any functions
Btw: After rolling back to 060 my registration information was gone and had to be re-entered
PostPosted: Thu Apr 28, 2016 9:40 pm
This is weird for multiple reasons! First, it works fine here (but that can happen if it's a different CPU). But what's stranger, if it crashes, you should *never* loose your old settings and registration info. This is scary... has anyone else seen this?
I do see that one of the GUI pages contains way too much things, maybe that could be causing a crash. So I will build a fix for that tonight.
PostPosted: Fri Apr 29, 2016 2:34 am
7.85 BETA062
Windows stand alone: http://www.stereotool.com/download/ster ... 85-062.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-062.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-062.dll
CHANGED:
- Fixed GUI bug. Maybe that fixes the gray screen that was reported by RadioImInternet - but I'm not too sure about that.
- Bug: Stereo Image Phase to 0 reduces L-R anti-phase sounds by about 6 dB, and also not constant. (This is new, used to be good before!) Problem occurs when feeding 100% anti-phase, even 1 degree difference between channels fixes it completely. -> Effect is reduced now, hopefully acceptable.
- Add Ratio to AGC
- Add Analyzer BYPASS mode (is that needed??) -> No, probably works already, but despite that, we can use a separate PC at the NAB for this.
- All L/R - L/R Quadrature mode, test with noise -> Doesn't work :(
- Add FM phase shift remover for high frequencies for Multipath
- Input Gain issue (see 2 posts below BETA054)
- LW SKIN!
- uM: Filter and add vac1/2/3/... option!
- Fixed broken VST plugin.
- Delossifier: Added MP3 detection filter; turn it on to disable the Delossifier when it thinks that the input is not an MP3.
- Delossifier: Protection added to not add too much. The result sounds cleaner, but it might also be slightly less effective. In total I think it's better.
- Detection and reconstruction both fail in 60's song Lay Down! -> Better now, but: 1. Make sure that this doesn't reduce repair elsewhere (some other parts are better now too, so be careful with that!). Maybe only remove narrow 'gaps' in the xmul array. 2. Improve detection to make Lay Down sound good always. It's not even an MP3! Check not only close to border but also a bit higher - should be nearly perfect silence! Maybe also some slowness in starting to repair?
- Absolute Highs: CRASH!
- Add Quadrature monitoring
- SPA remove monthly popup
- Added other optimizations
- Fix crash in BETA036.
- Exciter: Add Volume slider
- Exciter: Add DIFF mode
- Fixed crash when closing
- GUI: Added tooltips!
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- Exciter: Try to reduce pre-ringing (maybe by doubling overlap? Or measure on bigger block size, then go back to smaller?) Is this still a problem? -> Doesn't seem to be, removed.
- Fix AGC ratio display
- Absolute Highs: Optimize performance: Check log() -> Removed most (256 to 40 per step), and part of code that's not needed disabled for Delossifier.
- Crashes sometimes (since 061).
- Add separate watchdog process - see Zuidwest FM email dd 2016-04-20 12:24
- Delossifier: Lay Down breaks Delossifier, sounds really bad with MP3 detection turned off! (And it's not MP3). More accurate detection (smooth rolloff??) still needed, to also not detect it when not using Detect MPEG mode! Does Alternative Method sound better now?? Also try without HACK.
- OS X update wxWidgets for 10.10.5 compatibility.
- Make DIFFERENCE work in Natural Dynamics for separate bands
- Add auto detection of certain sound cards, like Marian Trace Alpha.
- Add RDS HTTP commands (Nashville)
- Add HTTP commands and feedback - viewtopic.php?f=16&t=7701&p=34436#p34436
- Add sound card adjustment presets for analog sound cards.
- Input Balance issue (see 2 posts below BETA054), cause known (reallocalte big buffer for waveform display, then buffer size doesn't match, and for some reason this causes a shift in time. However, calculated values appear to be correct. Check in more detail after NAB.)
- Normal Output: Don't output FM anymore!
- Absolute Highs: Check how slowly the frequency should rise. Probably should only be available if Delossifier freq responds slowly?
- License check
- set Encryption : impossible to view or modify all the processing settings
- Preset Licensing : encrypted preset without beeps unlocked by a license
LATER:
- O skin
PostPosted: Fri Apr 29, 2016 2:15 pm
I just had part of this (no GUI, bad audio) happening a moment ago. But so far I've been unable to reproduce it. Something is definitely wrong somewhere, also in the latest (062) version.
PostPosted: Sat Apr 30, 2016 3:30 am
7.85 BETA063
Windows stand alone: http://www.stereotool.com/download/ster ... 85-063.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-063.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-063.dll
CHANGED:
- Exciter: Try to reduce pre-ringing (maybe by doubling overlap? Or measure on bigger block size, then go back to smaller?) Is this still a problem? -> Doesn't seem to be.
- Add Ratio to AGC
- LW SKIN!
- OPTIMIZE DELOSSIFIER
- Check Sort algorithm optimization
- Clipper on separate CPU for ARM - or move around on cores?
- Absolute Highs: Check how slowly the frequency should rise. Probably should only be available if Delossifier freq responds slowly? (Maybe already ok?)
- License check
LATER:
- O skin
PostPosted: Sat Apr 30, 2016 11:54 pm
I got a crash on an older system, and I attached a debugger - looks like there's a stack overflow somewhere! Investigating...
PostPosted: Sun May 01, 2016 8:07 am
Anybody else been trying out the 'Multipath Stereo Phase Difference Remover'?
It sometimes seems difficult to (subjectively) know how much something is helping? I'd like to hear about other's experiences!
PostPosted: Sun May 01, 2016 12:45 pm
I'm not sure if it really does anything. It might. I have set the default values to 3500 / 6000, that seems to be the lowest that doesn't noticably reduce stereo separation when I listen on speakers. However, other people might hear things differently...
PostPosted: Sun May 01, 2016 2:01 pm
At initial startup of 063 Standalone on my main PC it crashed. Re-downloaded & installed again, got same result. Installed it into my Laptop and got input errors right away (Pictured)
Went back to my main PC and I opened 059 which works fine, reset all settings (Factory Reset), then I was able to keep 063 open. Clicked to use ASIO and it crashed again. Had to rest again with 059. Open 063 now it sounds terrible, went back to 059 it sounds clear.
PostPosted: Sun May 01, 2016 3:38 pm
If there's a stack overflow, anything can happen. It looks like I've fixed it now though - will post a new version tomorrow probably.
