BETA036:
Reduced CPU load, now equal to that of 6.10 (on my pc). May have some VERY VERY minor effect on channel separation (although I have not noticed it). I expect to be able to lower the CPU load a bit further in a day or 2.
No further changes.
Winamp DSP plugin:
http://www.stereotool.com/download/dsp_ ... 20-036.exe
Stand alone version:
http://www.stereotool.com/download/ster ... 20-036.exe BUILD FAILED: DISK FULL
VST version:
http://www.stereotool.com/download/vst_ ... 20-036.dll
VST version (No SSE2):
Command line version:
Linux command line version:
http://www.stereotool.com/download/ster ... ETA620-036 NOT AVAILABLE
Linux GUI version:
- Fix Punch
- Loudness: Annoying cracking sound in bass. Slightly present in 5.00, worse in 6.00, maybe even worse in 6.10. Only when bass is too loud. Much worse than in Final Limiter (at same input level!) - so this clearly indicates a bug. Most likely cause: The filter that was added to remove bass artifacts.......
- No, it's the louder bass. But it can be fixed by changing some settings. Default settings updated, and behavior for 'not Very strict' improved. Also Deep bass boost and Very deep bass protection are enabled for latency 512 now.
- Fix crash at program close
- Dynamically drop 'Allow louder highs, even if it causes vibrations' to 0 when bass filter suspects noticeable voice vibrations. 1-2 hours
- Reduce Loudness CPU load days?
- Finish new de-essing filter (check what to do with the settings, remove at least some!) 1 day
- Convert Multiband input to MONO, then use arrays [2][4096] --> should give speedup.
- Finish declipping filter (clipping level detection + level reduction in dB).
2 days
- Update presets? (BASS_AGC etc.)
1 day
- Finish blind interface
- Add AGC start level
- Change version number
1 hour
- Release
1 hour
