Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 758 posts ]  Go to page Previous 137 38 39 40 4176 Next
PostPosted: Thu Mar 22, 2018 11:21 am
https://ibb.co/gSCJ9c
stereo_tool_standalone_installer_64_BETA855-049 windows 7 64 bit
here just downloaded the new beta and as soon as tool starts, I get a white bar on the left. Sound comes through the tool but I can not change anything and can not close the tool.
I do this via task management.
sorry for the bad english I use google translate
probleem opgelost fout van mijn kant
PostPosted: Thu Mar 22, 2018 12:34 pm
Hi I upgraded and was shocked to see the new theme wchich I don't realy like so is it posible to get the old one back?
PostPosted: Thu Mar 22, 2018 12:51 pm
Configuration > Skin..
PostPosted: Thu Mar 22, 2018 3:03 pm
on beta 049 :
Sound is magnificent again. This auto eq is really the best addition so far for me.
Windows 10 Foobar 1.4 beta 9, Stereotool 8.55 beta 049 : auto equalizer > levels > effect strength .... changing level stops all processing, sometimes music slowly returns after 2 minutes
Somebody here suggested ST is responding different to other VST hosts so I tried Audacity. I don't know what I am hearing but is is not music so that was definitely true.
Does anybody know or have a suggestion about a free vst host that is able to run Stereotool 8.55 beta 049 VST version?
https://maasstad.online/
PostPosted: Thu Mar 22, 2018 3:36 pm
Check OcenAudio.
PostPosted: Thu Mar 22, 2018 7:31 pm
Also Wavosaur
It has a VST rack. :)
PostPosted: Fri Mar 23, 2018 8:50 am
Stereo Tool 8.55 BETA050
Windows stand alone: http://www.stereotool.com/download/ster ... 55-050.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 55-050.exe
VST: http://www.stereotool.com/download/vst_ ... 55-050.dll
OLDER CHANGES:
- New skin
- Fix Basstardizer crash
- Fixed Symmetric Peak
- Max release speed fixed
New AGC mode MORE INFO BELOW!
- RDS: Add PTYN
- RDS: Add timeout for TA
- VST version no 4K
- Backup input - check stereo
- Self test crashes
- Put Bass EQ under license
- Added Basstardizer
- Add low input level warning
- Added ASIO latency setting.
- Make OUTPUT_BB work with Basstardizer
- Quality slider extended to 150%
- near05 VST crash -> Added try/catch, maybe need to add logging as well. Let's first see if it still crashes.
- Aanvraag uren
- Check reported silence error - Maybe fixed?
- TURNED NAN LOGGING ON - IF A DIRECTORY C:\TEMP EXISTS, A FILE "LOG" WILL BE CREATED IN IT THAT LOGS WHERE NANS ARE ORIGINATING.
- Does ACR DIFF mode cause NAN's?
- Add AM presets
- Add new presets
- NAB stuff
- Classical preset
- Test NanoPi
- AM streaming output
- Multi-instance version
- AF method B via UECP
- 18 Hz trigger tone
- Declipper check L-R effects
- Reduce extreme stereo
- Check out Butt
- Omnia.9 test/fix logging
- WatchCat website
- Triple stuff
- uMPX 24x2ch interface
- One bass page
- Talk to chip
- 2 jaar
- Fardau
- -24 dB side chain range?
NOTE: Bass EQ
New compressor mode info:
Important: The CPU load is really high right now. I will optimize it later.
Also important: You can't just enable this new mode and expect everything to be fine without changing the settings. For small level differences there won't be a difference, but there will be for big differences. You'll definitely notice the slower attack on big level jumps.
PostPosted: Fri Mar 23, 2018 10:18 am
Thanks! Window size changes are fixed. :D
PostPosted: Fri Mar 23, 2018 11:34 am
I have a problem with Bass EQ. I have made a preset with bass eq activated. If I try to load the bass eq settings into another preset (LOAD / BASS EQ SETTINGS), they will not load. I've had this issue with previous beta versions too (standalone, W10 64bits).
PostPosted: Fri Mar 23, 2018 11:39 am
Ah. Oops. It was changing Auto EQ instead. Fixed. (Next beta)
