I play/test it with "Web radio Soft Compression" preset without Loudness... Singleband Prelimiter - first two sliders to 25.00.
Yes, 700Hz band drops as should.. but whole level is droped. Looking at
Breakaway RTA Scope, i clearly see whole level is down in that moment. It's better when i up Final Limiter to Make-it-up .. but i must put it to 1.50 and then it goes to hardRed (especially when FM output is used) which again is not good.
When i turn ON Loudnes seems it recover it a lot but .. what about when is Loudness is not needed. (as for my stream).
edit1:
I just put dsp ST default v4.22 to try fix it from SingleBand Compressor.. and seems it works very well, but little pumped, maybe i need to fine tune it .. ..
edit2:
Tuned! Almost ideal! i think this singleband comrpessor/limiter somehow need to be little smarter. tested over 100 songs of different genres .. and anyway much better.
btw: beta3 and beta3a are so better! i'l' wait singleband compressor/limiter fix and "gate"
edit3:
oh, i see Singleband is already fixed.
