Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 136 37 38 39 4059 Next
PostPosted: Tue Apr 26, 2016 7:08 am
Hi, Hans.
Can you check the following?
AM Stereo clipping flag. When turned off, output level indicator pretty much stays at top of scale and never comes out of red.
In AM mode, I assume you fixed enough headroom for asymmetry and any tilt adjustment? There used to be a setting under the asymmetry slider for that. When AM stereo clip flag is on, there seems to be a fixed amount that's fine. That goes away if you turn the flag off.
Speaking of tilt... If you're not using FM output, how do you go about adjusting a tilt setting for an AM transmitter? I haven't checked, but assume if I use the FM output for tilt and also flag on the AM setting (for asymmetry), I might be doing something bad to the pre-emphasis. In any case, doubling up on those settings does add a strange sound to the output!
Thanks!
-Jack
PostPosted: Tue Apr 26, 2016 5:04 pm
For tilt correction, use FM output also for AM. I need to check the red issue.
PostPosted: Tue Apr 26, 2016 9:46 pm
- agc meter always react like ratio is inf:1
- agc still works at 1:1
PostPosted: Wed Apr 27, 2016 1:27 am
Meter does indeed behave like that, but behavior doesn't (at least not with my settings). Can you make sure by setting ratio to 1:1? If it really doesn't work, please send me your settings so I can check what I missed.
PostPosted: Wed Apr 27, 2016 1:30 am
Hi, Hans.
Thanks!
-Jack
Please try lowering "Volume reduction for asymmetry headroom". Here that fixes it.
Having said that, it makes no sense that the stereo setting affects the behavior.
PostPosted: Wed Apr 27, 2016 6:53 am
7.85 BETA060
CHANGED:
- Add Ratio to AGC
Yeah! :D
PostPosted: Wed Apr 27, 2016 9:28 am
Hans, problem is with the ratio 1:1 it should do nothing, but apparently it is doing something ;) (at least looks like it). Check how the levels before/after look like.
PostPosted: Wed Apr 27, 2016 10:30 am
Tested again and ratio 1:1 seems ok.. AGC is doing nothing.
Meter is wrong.
PostPosted: Wed Apr 27, 2016 10:33 am
phew! :)
PostPosted: Wed Apr 27, 2016 11:54 am
7.85 BETA061
Windows stand alone: http://www.stereotool.com/download/ster ... 85-061.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-061.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-061.dll
CHANGED:
- Bug: Stereo Image Phase to 0 reduces L-R anti-phase sounds by about 6 dB, and also not constant. (This is new, used to be good before!) Problem occurs when feeding 100% anti-phase, even 1 degree difference between channels fixes it completely. -> Effect is reduced now, hopefully acceptable.
- Add Ratio to AGC
- Add Analyzer BYPASS mode (is that needed??) -> No, probably works already, but despite that, we can use a separate PC at the NAB for this.
- All L/R - L/R Quadrature mode, test with noise -> Doesn't work :(
- Add FM phase shift remover for high frequencies for Multipath
- Input Gain issue (see 2 posts below BETA054)
- LW SKIN!
- uM: Filter and add vac1/2/3/... option!
- Fixed broken VST plugin.
- Delossifier: Added MP3 detection filter; turn it on to disable the Delossifier when it thinks that the input is not an MP3.
- Delossifier: Protection added to not add too much. The result sounds cleaner, but it might also be slightly less effective. In total I think it's better.
- Detection and reconstruction both fail in 60's song Lay Down! -> Better now, but: 1. Make sure that this doesn't reduce repair elsewhere (some other parts are better now too, so be careful with that!). Maybe only remove narrow 'gaps' in the xmul array. 2. Improve detection to make Lay Down sound good always. It's not even an MP3! Check not only close to border but also a bit higher - should be nearly perfect silence! Maybe also some slowness in starting to repair?
- Absolute Highs: CRASH!
- Add Quadrature monitoring
- SPA remove monthly popup
- Added other optimizations
- Fix crash in BETA036.
- Exciter: Add Volume slider
- Exciter: Add DIFF mode
- Fixed crash when closing
- GUI: Added tooltips!
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- Fix AGC ratio display
- Add separate watchdog process - see Zuidwest FM email dd 2016-04-20 12:24
- Delossifier: Lay Down breaks Delossifier, sounds really bad with MP3 detection turned off! (And it's not MP3). More accurate detection (smooth rolloff??) still needed, to also not detect it when not using Detect MPEG mode! Does Alternative Method sound better now?? Also try without HACK.
- OS X update wxWidgets for 10.10.5 compatibility.
- Make DIFFERENCE work in Natural Dynamics for separate bands
- Add auto detection of certain sound cards, like Marian Trace Alpha.
7.85 but after NAB:
- Input Balance issue (see 2 posts below BETA054), cause known (reallocalte big buffer for waveform display, then buffer size doesn't match, and for some reason this causes a shift in time. However, calculated values appear to be correct. Check in more detail after NAB.)
- Normal Output: Don't output FM anymore!
- Absolute Highs: Optimize performance: Check log()
- Absolute Highs: Check how slowly the frequency should rise. Probably should only be available if Delossifier freq responds slowly?
- License check
- set Encryption : impossible to view or modify all the processing settings
- Preset Licensing : encrypted preset without beeps unlocked by a license
- Exciter: Try to reduce pre-ringing (maybe by doubling overlap? Or measure on bigger block size, then go back to smaller?) Is this still a problem?
LATER:
- O skin
