Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 135 36 37 38 3959 Next
PostPosted: Wed Apr 13, 2016 6:37 pm
I was sure that are a secret NAB words :)
PostPosted: Sat Apr 16, 2016 4:57 pm
7.85 BETA059
Windows stand alone: http://www.stereotool.com/download/ster ... 85-059.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-059.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-059.dll
CHANGED:
- Add FM phase shift remover for high frequencies for Multipath
(Note: But see new bug below, for absolute anti-phase it sounds bad, will look into that asap).
- Input Gain issue (see 2 posts below BETA054)
- LW SKIN!
- uM: Filter and add vac1/2/3/... option!
- Fixed broken VST plugin.
- Delossifier: Added MP3 detection filter; turn it on to disable the Delossifier when it thinks that the input is not an MP3.
- Delossifier: Protection added to not add too much. The result sounds cleaner, but it might also be slightly less effective. In total I think it's better.
- Detection and reconstruction both fail in 60's song Lay Down! -> Better now, but: 1. Make sure that this doesn't reduce repair elsewhere (some other parts are better now too, so be careful with that!). Maybe only remove narrow 'gaps' in the xmul array. 2. Improve detection to make Lay Down sound good always. It's not even an MP3! Check not only close to border but also a bit higher - should be nearly perfect silence! Maybe also some slowness in starting to repair?
- Absolute Highs: CRASH!
- Add Quadrature monitoring
- SPA remove monthly popup
- Added other optimizations
- Fix crash in BETA036.
- Exciter: Add Volume slider
- Exciter: Add DIFF mode
- Fixed crash when closing
- GUI: Added tooltips!
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- Add Ratio to AGC
- Bug: Stereo Image Phase to 0 reduces L-R anti-phase sounds by about 6 dB, and also not constant. (This is new, used to be good before!) Problem occurs when feeding 100% anti-phase, even 1 degree difference between channels fixes it completely.
- Add separate watchdog process - see Zuidwest FM email dd 2016-04-20 12:24
- Delossifier: Lay Down breaks Delossifier, sounds really bad with MP3 detection turned off! (And it's not MP3). More accurate detection (smooth rolloff??) still needed, to also not detect it when not using Detect MPEG mode! Does Alternative Method sound better now?? Also try without HACK.
- OS X update wxWidgets for 10.10.5 compatibility.
- Make DIFFERENCE work in Natural Dynamics for separate bands
- Add Analyzer BYPASS mode (is that needed??) -> No, probably works already, but despite that, we can use a separate PC at the NAB for this.
- All L/R - L/R Quadrature mode, test with noise -> Doesn't work :(
7.85 but after NAB:
- Input Balance issue (see 2 posts below BETA054), cause known (reallocalte big buffer for waveform display, then buffer size doesn't match, and for some reason this causes a shift in time. However, calculated values appear to be correct. Check in more detail after NAB.)
- Normal Output: Don't output FM anymore!
- Absolute Highs: Optimize performance: Check log()
- Absolute Highs: Check how slowly the frequency should rise. Probably should only be available if Delossifier freq responds slowly?
- License check
- set Encryption : impossible to view or modify all the processing settings
- Preset Licensing : encrypted preset without beeps unlocked by a license
- Exciter: Try to reduce pre-ringing (maybe by doubling overlap? Or measure on bigger block size, then go back to smaller?) Is this still a problem?
LATER:
- O skin
PostPosted: Mon Apr 18, 2016 3:38 pm
I have the latest version of the VST plug-in testing in ProppFrexx. Now I have the problem that the preset is not saved.
Regards,
Benny
PostPosted: Mon Apr 18, 2016 4:07 pm
Hans, latest beta version is the BEST !
But,
PLEASE tell us what are the optimum settings for the new feature ( multuipath stereo )
and WHAT should we do about the 0 degree phase shift ( should we activate stereo image and change the phase shift to other than 0 degrees ? )
:mrgreen:
PostPosted: Tue Apr 19, 2016 12:58 am
059 sounds great.
Look forward to being able to buy a key for Spectral Hole so I BEEP don't have to hear the BEEP BEEPing :)
Tim
PostPosted: Tue Apr 19, 2016 5:15 am
sounds very nice, is this the place to request having the linux vst for jack as a beta test version also?
https://maasstad.online/
PostPosted: Tue Apr 19, 2016 12:53 pm
But,
:mrgreen:
I don't know yet. Needs more testing! This Multipath Stereo is basically the Stereo Image filter, but only for the high frequencies, where your ears aren't very sensitive to phase information.
PostPosted: Thu Apr 21, 2016 3:43 am
I noticed this a week ago... with the VST version, the licensing information is saved and recalled in the VST settings, so... if for instance you load the VST with settings that have a previous licensing information, it won't use the latest entered licensing info. So you need to enter the key into the VST again (and re-save the chain/project/whatever). I didn't check to see if it effects the licensing of the standalone version.
I'm guessing that if the VST was loaded from someone else's project/chain/etc that it would use their licensing information instead of your own.
PostPosted: Sat Apr 23, 2016 5:47 am
Mathijs and I are on our way back from Vegas, so programming will start again next Monday (or sooner if I get bored this weekend, but I think I'm going to sleep for several days...). Posted from inside the plane from Seattle to Amsterdam :)
PostPosted: Mon Apr 25, 2016 10:35 pm
7.85 BETA060
Windows stand alone: http://www.stereotool.com/download/ster ... 85-060.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-060.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-060.dll
CHANGED:
- Add Ratio to AGC
- LW SKIN!
- Bug: Stereo Image Phase to 0 reduces L-R anti-phase sounds by about 6 dB, and also not constant. (This is new, used to be good before!) Problem occurs when feeding 100% anti-phase, even 1 degree difference between channels fixes it completely. -> Effect is reduced now, hopefully acceptable.
- Fix AGC ratio display
- Add auto detection of certain sound cards, like Marian Trace Alpha.
7.85 but after NAB:
- License check
LATER:
- O skin
