7.85 BETA058
Windows stand alone:
http://www.stereotool.com/download/ster ... 85-058.exe
Winamp DSP:
http://www.stereotool.com/download/dsp_ ... 85-058.exe
Windows VST 32 bit:
http://www.stereotool.com/download/vst_ ... 85-058.dll
CHANGED:
Correct build now. I'm flying to the NAB in Las Vegas in 2 days, so updates will be slow in the next week (although I have one thing I might add during the flight, so I can show it there
- Input Gain issue (see 2 posts below BETA054)
- LW SKIN!
- uM: Filter and add vac1/2/3/... option!
- Fixed broken VST plugin.
- Delossifier: Added MP3 detection filter; turn it on to disable the Delossifier when it thinks that the input is not an MP3.
- Delossifier: Protection added to not add too much. The result sounds cleaner, but it might also be slightly less effective. In total I think it's better.
- Detection and reconstruction both fail in 60's song Lay Down! -> Better now, but: 1. Make sure that this doesn't reduce repair elsewhere (some other parts are better now too, so be careful with that!). Maybe only remove narrow 'gaps' in the xmul array. 2. Improve detection to make Lay Down sound good always. It's not even an MP3! Check not only close to border but also a bit higher - should be nearly perfect silence! Maybe also some slowness in starting to repair?
- Absolute Highs: CRASH!
- Add Quadrature monitoring
- SPA remove monthly popup
- Added other optimizations
- Fix crash in BETA036.
- Exciter: Add Volume slider
- Exciter: Add DIFF mode
- Fixed crash when closing
- GUI: Added tooltips!
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- Add FM phase shift remover for high frequencies for Multipath
- Bug: Stereo Image Phase to 0 reduces L-R anti-phase sounds by about 6 dB, and also not constant. (This is new, used to be good before!) Problem occurs when feeding 100% anti-phase, even 1 degree difference between channels fixes it completely.
- Delossifier: Lay Down breaks Delossifier, sounds really bad with MP3 detection turned off! (And it's not MP3). More accurate detection (smooth rolloff??) still needed, to also not detect it when not using Detect MPEG mode! Does Alternative Method sound better now?? Also try without HACK.
- Add Analyzer BYPASS mode (is that needed??) -> No, probably works already, but despite that, we can use a separate PC at the NAB for this.
- All L/R - L/R Quadrature mode, test with noise -> Doesn't work
7.85 but after NAB:
- Input Balance issue (see 2 posts below BETA054), cause known (reallocalte big buffer for waveform display, then buffer size doesn't match, and for some reason this causes a shift in time. However, calculated values appear to be correct. Check in more detail after NAB.)
- Normal Output: Don't output FM anymore!
- Absolute Highs: Optimize performance: Check log()
- Absolute Highs: Check how slowly the frequency should rise. Probably should only be available if Delossifier freq responds slowly?
- License check
- set Encryption : impossible to view or modify all the processing settings
- Preset Licensing : encrypted preset without beeps unlocked by a license
- Exciter: Try to reduce pre-ringing (
maybe by doubling overlap? Or measure on bigger block size, then go back to smaller?) Is this still a problem?
LATER:
- MB: Add voice volume protection, don't allow mid bands to drop below surrounding (to some extent), protectes voices and it might help to replicate the sound of certain other processors
- O skin
