Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 133 34 35 36 3759 Next
PostPosted: Thu Apr 07, 2016 7:13 pm
Which version? (Winamp, VST, stand alone?)
In the VST Version. I already tried to delete the settings file in the user directory. but it don't change anything.
PostPosted: Thu Apr 07, 2016 9:15 pm
vst issue, no access to configuration.
Last working version was for me 7.85-052
I use stereotool in Wavelab 7.2.1
PostPosted: Thu Apr 07, 2016 11:43 pm
I think that I've fixed the VST issue, building an update now.
I accidentally enabled the "MPX Analyzer" in the VST plugin, which requires a 2nd input channel, which doesn't exist in VST.
PostPosted: Thu Apr 07, 2016 11:44 pm
7.85 BETA056
Windows stand alone: http://www.stereotool.com/download/ster ... 85-056.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-056.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-056.dll
CHANGED:
- Fixed broken VST plugin.
- Delossifier: Added MP3 detection filter; turn it on to disable the Delossifier when it thinks that the input is not an MP3.
- Delossifier: Protection added to not add too much. The result sounds cleaner, but it might also be slightly less effective. In total I think it's better.
- Detection and reconstruction both fail in 60's song Lay Down! -> Better now, but: 1. Make sure that this doesn't reduce repair elsewhere (some other parts are better now too, so be careful with that!). Maybe only remove narrow 'gaps' in the xmul array. 2. Improve detection to make Lay Down sound good always. It's not even an MP3! Check not only close to border but also a bit higher - should be nearly perfect silence! Maybe also some slowness in starting to repair?
- Absolute Highs: CRASH!
- Add Quadrature monitoring
- SPA remove monthly popup
- Added other optimizations
- Fix crash in BETA036.
- Exciter: Add Volume slider
- Exciter: Add DIFF mode
- Fixed crash when closing
- GUI: Added tooltips!
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- Input Gain issue (see 2 posts below BETA054)
- LW SKIN!
- RJ45!!!!!!!!!! -> M.A
- uM: Filter and add vac1/2/3/... option!
- Add FM phase shift remover for high frequencies for Multipath
- Delossifier: Lay Down breaks Delossifier, sounds really bad with MP3 detection turned off! (And it's not MP3). More accurate detection (smooth rolloff??) still needed, to also not detect it when not using Detect MPEG mode! Does Alternative Method sound better now?? Also try without HACK.
- Add Analyzer BYPASS mode (is that needed??) -> No, probably works already, but despite that, we can use a separate PC at the NAB for this.
- All L/R - L/R Quadrature mode, test with noise -> Doesn't work :(
7.85 but after NAB:
- Input Balance issue (see 2 posts below BETA054), cause known (reallocalte big buffer for waveform display, then buffer size doesn't match, and for some reason this causes a shift in time. However, calculated values appear to be correct. Check in more detail after NAB.)
- Normal Output: Don't output FM anymore!
- Absolute Highs: Optimize performance: Check log()
- Absolute Highs: Check how slowly the frequency should rise. Probably should only be available if Delossifier freq responds slowly?
- License check
- set Encryption : impossible to view or modify all the processing settings
- Preset Licensing : encrypted preset without beeps unlocked by a license
- Exciter: Try to reduce pre-ringing (maybe by doubling overlap? Or measure on bigger block size, then go back to smaller?) Is this still a problem?
LATER:
- O skin
PostPosted: Fri Apr 08, 2016 10:07 pm
VST configuration issue solved.
Thanks
PostPosted: Sat Apr 09, 2016 8:07 am
Hi! Input gain and Balance (in Configuration -> Sound cards -> Input -> Low input level correction) are completely ineffective since BETA785-054 in standalone version.
viewtopic.php?f=14&t=6087&start=310#p30034 <-This problem is still exists, but only on 4096 samples latency.
PostPosted: Sat Apr 09, 2016 3:27 pm
I really think you should keep the old single band as alternative. It is super easy to understand and handle: "Maximum Volume" to push the volume to the limit without clipping, "Compress/Limit" slider to push loudness further by adding compression without causing clipping. It took me 5 minutes to understand this and getting results I was happy with. I still havent figured out how to emulate the "Compress/Limit" slider with the new single band.
PostPosted: Sat Apr 09, 2016 3:58 pm
I went through the different versions of Stereotool and the most distortions seem to appear with 7.71. The 7.70 only has some minor additional "clicks" compared to the 7.03. It begins with 7.41.
7.03 and 7.40 are the same (my piano example WAV mixed with switched phase):
The first differences appear with 7.41:
This is the difference between 7.03 and the current beta:
PostPosted: Sun Apr 10, 2016 2:19 am
Hi, Hans.
PLEASE work up a price for the delossifier section, so I can license a version and try it on a real radio station. I can't do that as long as it beeps and tells people to go to the web site! :-)
PostPosted: Sun Apr 10, 2016 8:54 am
Hi, Hans.
Same here! I have a station running with a library full of MP3 (sic), that would be great to try it on live! :)
