Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 345 posts ]  Go to page Previous 131 32 33 34 35
PostPosted: Mon Aug 10, 2015 11:04 am
Whole GUI laggy -> that's true (effect shouldn't be TOO big though) - data is generated for bigger chunks of audio, which means that there's less data (about 20%, if you set it to 19 kHz with 48 kHz sample rate).
Yep but for some reason when you set the cpu load (quality slider) lower it gets even laggier.
That also makes it process in bigger chunks. If you set the Latency slider slower it will go faster again, but that also affects the quality... Anyway, it's not that strange that if you use settings that affect the sound quality (Quality slider, 'Ignore frequencies above' shouldn't affect the sound quality) the GUI also gets laggier...
PostPosted: Mon Aug 10, 2015 11:07 am
Stereo Tool 7.71 BETA028 - RELEASE CANDIDATE
Windows stand alone: http://www.stereotool.com/download/ster ... 71-028.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 71-028.exe
Windows 32 bit VST: http://www.stereotool.com/download/vst_ ... 71-028.dll
- Check input levels (arche)
- Sluggish meters (declipper) - probably ignore for now...
- Add Facebook, Twitter, LinkedIn buttons to About box :)
- Fix Low Latency Monitoring output PNR bug
- Fix SCA generation
- Add delay (in samples) for one of the two MPX channels to send audio to allow synchronization of 2 transmitters which use the same frequency. (John Markis)
- Change default preset to something useful
- Change version number to 7.71
- Synchronization is broken in 008 (was ok in 007) - Don't see it! Is anyone still seeing this? - No response, assuming ok.
- Fix Mac VST version (not recognized apparently) - Tested 025 in Reaper, works fine.
- Remove About photo
- Add presets
- Fix Linux version (someone mentioned that it crashes after a few minutes, on Ubuntu 14.04 - re-check with Valgrind) -> Done, found a few issues, Valgrind shows 0 errors now both for command line and GUI versions.
- Reduce memory usage further (check all MAX_SAMPLES_44K arrays including SS and multi_samples) - Effect is small (about 0.5 MB) - not worth the effort.
- Check all #pragma messages.
- Fix >48 kHz Normal Output issue in stand alone version.
- Fix reported glitches/hiccups?
- Optimized Stokkemask exciter code
- Optimized output to lower sample rate sound cards (includes plugin hosts). Overhead (CPU load even when all processing is disabled) is greatly reduced.
Risky change.
- Tested a large number of other small things (there were a bunch of remarks that I placed throughout the code, and most of them are removed now).
- Fixed FM tilt correction GUI issue.
- Exception reported by DJ_DOGGY fixed.
- Make OldSamples buffers (and potentially others) dynamic to save memory - Currently allocating 85 MB just to display waveforms!!!
- Optimize memory usage: Don't allocate more than MAX_SAMPLES_ST for blocks which only get downsampled audio. So only allocate a few things bigger.
- Change tone generation FM enable/disable and order.
- VST multiple instances fails - Tested and works fine. Ignoring unless I'm receiving a better report. Note: 32 bit too many instances can crash due to the 2 GB limit. Max number is now 3, used to be 6 so some optimization could be useful.
- Make VST window bigger
- Fixed Quality slider bug introduced in previous beta
- Fixed jumping pilot and RDS effect on some 'Ignore frequencies above' frequencies.
- Sometimes the top and bottom waveforms run at different speeds when Ignore Frequencies Above is enabled.
- Make Chain block (small size) based - Partially done
- Declipper display is broken. Even without Ignore Frequencies Above. Ok upto 100 ms. Also broken in 7.70!!! Only if samplerate > 48 kHz, and when switching between sizes, upto 100 ms everything is fine (even if no audio is playing so no refresh of the data occurs), so the bug is in the displaying code. -> Was a shift error, fixed.
- Again, fixed noise level jumps and spike at Ignore Frequencies Above frequency.
- Clipper issues Leif / Wolf Stahl (probably the same thing) - Should be fixed now. - Waiting for reply Wolf- Check new clipper highs
- Remove "Take some shortcuts" under CPU, probably broken! And has not much effect anyway. -> Hm, no, must have been in use for the tests. Ugh... TEST to check what is better: ON (which will probably allow more sounds through) or OFF. -> Actually it does seem to work AND allow more highs through, but I don't know if that's a good thing - more tests needed!
- Added lowpass filter after clipper in non-composite mode.
- Fixed problem with click sounds (reported by DJ_DOGGY). Reduced output level by 1% - you can safely increase modulation by 1% if you're using an output that's affected by this (should only be FM signal inside a plugin). If you're using the stand alone version, make sure to set the output level to the sound card no higher than 99% (-0.1 dB).
- Fix downsampling and Quality slider problems: Lower Quality setting
- Attempt to reduce effect on volume of using Leif's clipping method.
- Fix DJ Doggy's reported errors (19 kHz, junk around tones).
- Ignore frequencies above a specific frequency -> Should lower TOTAL CPU load by another 10-20% (now fully implemented except at lower Quality settings)
- Fixed the lowpass bug that was introduced in 009. Although it has probably always been there! As a side effect, the output is also slightly louder (about 0.02 dB) with no negative effects.
- Fixed distortion introduced in 009/010. Extra highs are still there though! See new 'Sparkling highs' section under Advanced Clipper -> Sound
- Fix optimizations
- Fix code #warnings
- Some small optimizations
TO DO 7.71:
- Test O9SG build
- Release
TO DO 7.72:
- BS412 boost-at-start
- Add impulse response import function!!!
- Noise learning Micha
- HQ mode is broken.
- EQ with 'standard' sliders.
PostPosted: Mon Aug 10, 2015 11:12 am
At beta 27 the mux delay will add delay properly up to 199 samples but at 200 samples it will be back to no delay. I don't actually care as I need just 33 samples, and most ppl would be fine with just 200 samples delay which equals to 300km delay @ 192KHz. So Just tweak the delay UI to be up to 199 samples and it will be just fine.
Seen with an oscilloscope using ASIO and a XONAR DX (I know, I know lol ) sound card.
I need to fix all STL's in perfect audio levels in order to check the feature's effectiveness, I hope I''l be able to test it today. I'm really excited about it.
PostPosted: Mon Aug 10, 2015 11:24 pm
I must say that I'm impressed with the progress in optimizations.. My i5-3320m laptop is running everything nice and smooth even when every FM setting is maxed (strictness etc.).. Only the declipper is running too hot, if I increase the step size reduction from 89% to 99% it starts to choke :)
PostPosted: Tue Aug 11, 2015 12:40 am
And we have a release!
viewtopic.php?f=14&t=6142
I've just measured the CPU load reduction, and with 'Ignore frequencies above' set to 19 kHz, running a full FM preset with composite clipper uses upto 45% less CPU power compared to version 7.70 (!).
